RC Injector sealing problem
Old May 2, 2009 | 01:59 PM
IntegraG2's Avatar
Default RC Injector sealing problem
Im basically done my turbo install but there is one problem I am running into but cant figure out. I know most people had problems with their o-ring not fitting making the injector not sit correctly into the IM but my problem is that gas is pissing out where the injectors are in the fuel rail. I am using oem gromets and the insulator/rubbing thing on the top of the injector. It seems like my injector clip (pheable obd1 to obd2 conversion harness) is pushing on the insulator making it not seal correctly. I need honda-tech's help. I have tried 2 different fuel rails now and still the same shiz is happening.
Thanks,
Les
Old May 2, 2009 | 03:19 PM
1992Si's Avatar
Default Re: RC Injector sealing problem
Do you have all the o-rings ?
http://www.acuraautomotiveparts.org/...s=&view=normal
Old May 2, 2009 | 05:47 PM
IntegraG2's Avatar
yes i do have all the o-rings...for the top i have the insulator (cushion seal) then the o-ring that goes on top of that.
Old May 2, 2009 | 09:31 PM
KWayRacing's Avatar
look at the o rings on the top of the injector they are probably cut or used. those orings are almost disposable as in one time use only. Try a slightly emphasis on slightly thicker upper o ring
Old May 3, 2009 | 07:58 PM
IntegraG2's Avatar
It seems like the injector clip is pushing on the seal making a space for the fuel to spray out of. Any idea here. I will get a picture of what I mean by tomorrow.
ok out of this picture what seals am I supposed to be using for the top.
Old May 4, 2009 | 12:23 PM
wraith646's Avatar
the o-ring is to small you can use orings for A/C they are ticker and still fuel resistant. remember to spit on the ring to push into the rail. if not it will roll and not sit right
Old May 6, 2009 | 11:03 AM
IntegraG2's Avatar
ok i will try the A/C o-ring. I will update on if this works or not
Old May 7, 2009 | 12:28 PM
IntegraG2's Avatar
Update: I used brand new OEM o-rings and there are no more leaks. It was a bit tough to get the ring inside the fuel rail properly so I put 2 smaller o-rings on the injector before the OEM one so the OEM o-ring wouldnt shift around and it slid into the fuel rail with ease.
So for anyone else that has this problem make sure to use smaller o-rings before the OEM one in order to put equal pressure on the OEM o-ring going into the rail. Dont forget some grease on the outside.
Thanks Honda-Tech.
Old May 8, 2009 | 08:26 AM
Flashmn's Avatar
Thats not too smart, adding unnecessary o-rings might cause problems with the actual O-ring. I'd keep it like it is. I know its hard to get in and its supposed to be, some lube helps.
slideintegra08
Jun 5, 2012 01:45 PM
Tomservo
Jul 12, 2006 10:40 PM
b00sted4dr
Feb 7, 2005 10:50 AM
civicon19s
Jul 25, 2002 12:07 PM
