Rattling noise in head when cold
Old Aug 24, 2004 | 10:58 PM
iiilgsrlll's Avatar
Default Rattling noise in head when cold
So my motor is back together and running perfect EXCEPT for a weird rattling noise which sounds like its coming from the head near the distributor when cold. When the motor is warm it goes away completely. This happens when you rev it up slightly around 2000-2500 rpm then goes away.
Does anyone have an idea of what it could be? We were thinking valve lash, distributor bearing failing, or LMA?
I'm leaning towards lash because it goes away completely when warm but anyone else care to chime in?
Old Aug 25, 2004 | 12:30 AM
anothersickhatch's Avatar
Default Re: Rattling noise in head when cold (iiilgsrlll)
VALVE ADJUSTMENT
Old Aug 25, 2004 | 02:22 PM
iiilgsrlll's Avatar
Anyone else?
Old Aug 25, 2004 | 03:33 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else?</TD></TR></TABLE>
Could also be a bad LMA.
Old Aug 31, 2004 | 02:28 PM
iiilgsrlll's Avatar
Could a bent rocker shaft cause the rattling?
Don't ask how it got bent because I don't know. We're thinking the machine shop had something to do with it.
Old Aug 31, 2004 | 02:41 PM
skunked's Avatar
how would a bent rocker shaft get in the head? It wouldn't be able to slide in....
Old Aug 31, 2004 | 02:51 PM
iiilgsrlll's Avatar
Default Re: Rattling noise in head when cold (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">how would a bent rocker shaft get in the head? It wouldn't be able to slide in....</TD></TR></TABLE>
It was never removed. Everything was left intact except the cams when sent to the machine shop. It was there for the purpose of checking for straightness and resurfacing.
Old Sep 2, 2004 | 06:10 PM
TypeRcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">So my motor is back together and running perfect EXCEPT for a weird rattling noise which sounds like its coming from the head near the distributor when cold. When the motor is warm it goes away completely. This happens when you rev it up slightly around 2000-2500 rpm then goes away.
I'm leaning towards lash because it goes away completely when warm but anyone else care to chime in?</TD></TR></TABLE>
How loud is the rattle. Sounds funny, but does it kinda sound like a sewing machine? I have an ITR and it rattles a little in the winter. Once it warms up, it goes away. Its probably nothing. What kind of cams? My valves are adjusted fine.
Old Sep 2, 2004 | 06:22 PM
iiilgsrlll's Avatar
Default Re: Rattling noise in head when cold (TypeRcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRcivic &raquo;</TD></TR><TR><TD CLASS="quote">
How loud is the rattle. Sounds funny, but does it kinda sound like a sewing machine? I have an ITR and it rattles a little in the winter. Once it warms up, it goes away. Its probably nothing. What kind of cams? My valves are adjusted fine.</TD></TR></TABLE>
I guess you can say it sounds like a sewing machine. Its more comparable to rocks in a can rattling around. It only does it in the very low rpm range when cold. I only hear it when free revving. I am still using stock GSR cams.
Old Sep 2, 2004 | 06:44 PM
mmuller's Avatar
Mad Scientist
yeah, it sounds like detonation.
mine does the same and im like 90% sure its the lma's
Old Sep 3, 2004 | 10:02 PM
iiilgsrlll's Avatar
Default Re: Rattling noise in head when cold (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">yeah, it sounds like detonation.
mine does the same and im like 90% sure its the lma's </TD></TR></TABLE>
It ends up being that the machine shop didn't fully torque something down after they removed the part for cleaning. The problem has been resolved. Thanks for all of those that replied.
ronqqq
Sep 26, 2006 07:32 AM
JDM SLICK
Jun 19, 2006 06:20 PM
DigitalFusion
Aug 5, 2004 07:29 PM
hatchdrvr
May 27, 2004 06:00 PM
FMIDRC Racer
13
Oct 20, 2003 07:57 PM
