R/S Ratio help..
Old Oct 20, 2003 | 01:59 PM
crxsirvtec's Avatar
Default R/S Ratio help..
i have a LS block and Crank..
i want to know what crank will give me the best R/S ratio
B16, GSR or LS
Also what CC i would get with a B16/gsr/LS at 85MM
Thanks
Old Oct 20, 2003 | 06:01 PM
Propulsion's Avatar
Default Re: R/S Ratio help.. (crxsirvtec)
b16 crank would yield the best ratio. Go to c-speed.com to calculate compression/displacement
Old Oct 20, 2003 | 07:19 PM
crxsirvtec's Avatar
what will the r/s ratio be??
Old Oct 20, 2003 | 07:27 PM
pro1342's Avatar
With a B16 the r/s ratio would be 1.85, but if you used a B17 crank it would be 1.75.....perfect.
Old Oct 21, 2003 | 12:25 AM
Wilky's Avatar
I know there have been posts on here before, but how important is R/S ratio really. Anybody have any real experience, bad or otherwise, with really wacky stroker-induced ratios. I have read a few commentaries about how far too much attention is given to this. Any thoughts?
Old Oct 21, 2003 | 04:58 AM
StyleTEG's Avatar
Default Re: R/S Ratio help.. (Wilky)
Its very important if you plan to rev the engine high.
Take a look at this graph of piston velocity vs crank angle at 9000rpm with different r/s ratios.
The differences of the crank angle at TDC and BDC are pretty apparent.
Old Oct 21, 2003 | 07:22 AM
Wilky's Avatar
Default Re: R/S Ratio help.. (StyleTEG)
I understand that there are going to be differences with the angles of the rods, etc. But what does that really mean for performance and reliability? Can't you have a terrible ratio with strong parts and still have performer? I see and understand the numbers but has anyone actually had engine problems or failure that they can directly attribute to a bad R/S ratio?
Old Oct 21, 2003 | 10:52 AM
Lsos's Avatar
R/S ratio actually has a very small effect on maximum piston acceleration. Stroke is mainly responsible for the differences on that graph. It's more side loading that's the main issue.
Mref813
Dec 28, 2009 09:34 PM
EM1PILOT22
Oct 20, 2009 10:49 AM
bottlefed1
Mar 18, 2005 08:52 PM
scrambledeg
Dec 14, 2003 10:52 PM
eddiecut
Feb 2, 2003 10:35 AM
