Quick question about IACV recently cleaned
Old Oct 25, 2009 | 09:08 AM
langjairicer's Avatar
Default Quick question about IACV recently cleaned
So...I have the lumpy Idle problem and I attempted to remove, clean, and re attach it (following the simple instructions provided on a stickied write up). After cleaning the IACV and re-attaching the intake, the problem has ceased to go away. But moreover, I hear this very prominant "PSssSshhhhhhhhhh...hh..." (kind of like a turbo noise) spooling down and I think it is coming from the intake. Is this an air leak from the intake or is it supposed to make this noise and I have just never heard it before? Could it have anything to do with the coolant tubes connected to the IACV?
Much obliged in advance.
Old Oct 27, 2009 | 09:41 PM
worlds-slowest-EG's Avatar
Default Re: Quick question about IACV recently cleaned
very typical sound for hondas or any car w/ an aftermarket intake
it's really the way that it should sound when the valve is clear, just did mine yesterday same result.
Old Oct 28, 2009 | 07:54 AM
mouab18c1's Avatar
as long as your not overheating and re bled your coolant system after taking the IACV off then you should be good
Old Oct 28, 2009 | 09:34 AM
Alright this problem has been solved. I wasn't aware I needed to bleed the coolant systen haha. Thanks for the input
krysted9354
11
Mar 4, 2009 04:27 PM
deadmemoryy
Dec 12, 2007 08:24 PM
Rex-Si
Jun 10, 2006 07:45 PM
carracr625
May 25, 2005 06:14 PM
McNizzle
25
Oct 2, 2004 06:18 PM
