quick injector question
Ok I know about the peak and hold and the saturated.. But my question is does it matter if they are OBD1 or OBD2? We're looking for some injectors for my wifes car but if I buy a set from a 99-00 SI greddy kit will they work on an OBD1 car? TIA
You can measure the resistance with a micrometer... I don't remember the values.
Another easy way to tell.. if it has a resistor box, it is peak and hold. If there is no resistor box, they will be saturated.
If you buy saturated injectors, and you have a resistor box.. just remove it. You can always install a resistor box if need be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">The injectors will work, but you will need to replace the car's current injector clips with a set of OBD2 clips. </TD></TR></TABLE>
Oh ok...so the only diff. is the clips? thanks that's what I was looking for...
