questions about fuel regulator!
Old Sep 25, 2002 | 01:24 AM
JDM-FREAK's Avatar
Default questions about fuel regulator!
hi, i installed fuel regulator while ago, and it stays at 40.. but, i want it to be at 35 instead of 40, can someone teach me how to adjust it?....
Old Sep 25, 2002 | 09:57 AM
TimoneX's Avatar
New User
Default Re: questions about fuel regulator! (takumi_79)
Is it the B&M command flo unit?
If so then just pull the vacuum line going to it, loosen the 13mm? nut, then rotate the fitting. Clockwise increases pressure, counter-clockwise lowers it, if I recall arightly.
Old Sep 25, 2002 | 12:42 PM
JDM-FREAK's Avatar
Default Re: questions about fuel regulator! (TimoneX)
thanks a lot.. i can't believe i didn't try that.. ...
newayz, whatz the best set up if you only have i/h/e?.. i had them put it at 40psi,
but, i changed to 35psi .. any recommend?
[Modified by takumi_79, 3:42 PM 9/25/2002]
Old Sep 25, 2002 | 12:49 PM
TimoneX's Avatar
New User
It's really car specific, but I'd think 40psi would be closer to optimal than 35psi. I never messed with mine extensively till I had I/H/E and 63403 Crower cams on there. Make small adjustments and see how it goes. I carry the 2 wrenches with me pretty much all the time and make small changes to this. It makes a big difference. Really w/o wideband tuning or at least a good gauge you're shooting in the dark.
turboef90
Aug 11, 2013 12:28 PM
civicsit
Sep 12, 2006 01:21 PM
6_GeArEd_TEG
Nov 27, 2004 09:57 PM
nd94cx
Sep 16, 2004 07:03 AM
nema741
Apr 23, 2003 07:26 AM
