cylinder three has low compression (125psi) Help!
Old Sep 25, 2002 | 11:10 AM
Death_to_Thieves's Avatar
Default cylinder three has low compression (125psi) Help!
Whats up guts I have a B17a and I had a compression test done on it at the dealership and they told me that cylinder 3 has low compression(125psi) but all others are at 195. What could be causing this and how could I fix it?? Thanks
Old Sep 25, 2002 | 11:19 AM
CHEETAH's Avatar
Default Re: cylinder three has low compression (125psi) Help! (8000KReV)
they should have done a leakdown for you and tell you what was causing it, can be piston rings, headgasket, valveseal or even a cracked piston ... hard to say from a simple compression number.
Greg
Old Sep 25, 2002 | 11:22 AM
Spade's Avatar
Re-test.....verify low
Add 1 teaspoon of oil then test again. If still low = Head.
If raises = Piston rings.
Old Sep 25, 2002 | 12:00 PM
Turbo Powa's Avatar
Default Re: cylinder three has low compression (Spade)
Old Sep 25, 2002 | 12:38 PM
BrandonClaps's Avatar
New User
where do you add the teaspon? right into the spark plug opening or in the oil fill cap on valve cover?
Old Sep 25, 2002 | 12:49 PM
3rdGteg's Avatar
Default Re: cylinder three has low compression (BrandonClaps)
Yeah right into the plug opening. Also I'd get a leakdown test too.
[Modified by 3rdGteg, 9:50 PM 9/25/2002]
724chris
Nov 1, 2009 05:47 PM
cxVtecC1
Feb 18, 2005 06:54 AM
Calvinator
Nov 14, 2004 09:28 PM
greenli0n25
Jan 26, 2004 07:29 AM
RedRacerCivic
11
May 22, 2003 10:29 AM
