question on shock installations
Old Aug 6, 2003 | 06:42 AM
dip-set's Avatar
Default question on shock installations
at the top of the shock towers where they bolt down (2 nuts to each shock) do the require a washer of some sort before the nut goes on or just the nut...what are the correct torque numbers for those nuts...what would be the best spray lube to use on all suspension bushing...thanks
Old Aug 6, 2003 | 09:02 AM
IN VTEC's Avatar
Default Re: question on shock installations (teg-your-it)
Only if you're not using flange nuts will you have to use a washer.
36lb*ft for all 4 corners.
I've found the best success with PB Blaster. Altho, it's hard to get the spray to penetrate into the problem threads, irregardless of spray used, at least it helps when you're threading the nut off or bolt out after it's broken loose.
Old Aug 6, 2003 | 09:44 AM
dip-set's Avatar
Default Re: question on shock installations (IN VTEC)
thanks IN VTEC but the spray lube i was referring to is not to help with removing bolts/nuts but just as a lubricant for the bushing and such..(oem bushing,i just want to lube them up with some kinda spray/grease..i heard wd40 deteriorates them)
36lbs*ft torque ..i would think more than that...
Old Aug 6, 2003 | 11:15 AM
IN VTEC's Avatar
36lb*ft is quite a bit and what the factory specifies.
Don't use spray lube, use a general purpose grease or a moly-based grease.
Old Aug 6, 2003 | 11:20 AM
dip-set's Avatar
ok but to use the grease i would have to disassemble the suspension components and i realy dont want to go thru all that just to grease it up...i was hoping i could soak the bushing with some kinda spray lube....any other suggestions...? white litheum grease?
Old Aug 6, 2003 | 11:41 AM
IN VTEC's Avatar
You'll never get the grease evenly throughout the bushing without disassembling it.
Lithium spray is still too thick to make its way into the bushing. It'll just cake up on the edges.
Try PB Blaster. Not really what people intend it for, but it's a thin-film liquid with some film longevity even after drying up.
Old Aug 6, 2003 | 11:45 AM
dip-set's Avatar
so none of those silicone sprays are worth it huh...it will get rinsed away easily with the rain...i"ll try the pb blaster but isnt it going to deteriate(sp) the bushings as wd40 would?
sorry for all the questions
Old Aug 6, 2003 | 11:55 AM
dip-set's Avatar
let me add another question in here instead of a new thread...
what will happen when u have stock springs with shocks like illuminas,agx,koni yellows,and the spring rate is too soft for the shocks...
Old Aug 6, 2003 | 03:39 PM
IN VTEC's Avatar
No such thing as the spring rates being too soft for the shocks.
Old Aug 6, 2003 | 07:41 PM
Mohudsolo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">No such thing as the spring rates being too soft for the shocks.</TD></TR></TABLE>
I would have to disagree. I'm pretty sure if I put stock springs on my Konis that are valved for 800lb springs, there would be way too much rebound and they would not work well at all.
However, the shocks he mentioned will all work fine with stock springs. The Tokiko and KYB are made for stock or near stock spring rates and I think the Koni will work fine too. Most commonly available shocks can be overwhelmed by spring rates that are too high, due to not being race shocks.
1990IntegraLS
Aug 15, 2015 06:29 AM
gitrdone
Honda Civic (2001 - 2005)
Jul 9, 2006 03:54 AM
AZNracerx1989
Jan 2, 2006 02:40 PM
DC4_MADMAN
Suspension & Brakes
Jul 6, 2005 09:11 AM
Chronicsinners
Feb 20, 2003 12:20 PM
