adding oil for compression check
Old Nov 11, 2003 | 11:17 AM
Jer Del Sol's Avatar
Default adding oil for compression check
when doing a compression check.. to see if its the valves... head gasket... or piston rings... u can add oil into the chamber... how much oil do you add?
Old Nov 11, 2003 | 11:18 AM
-Trinitron-'s Avatar
Default Re: adding oil for compression check (Jer Del Sol)
That is for checking the rings to check the seal. You are supposed to add 6-8 sqirts from a diaphram style oil can.
Old Nov 11, 2003 | 11:20 AM
Muckman's Avatar
Moderator in Chief
I use a tablespoon worth.
Old Nov 11, 2003 | 12:13 PM
Hammett's Avatar
if you want to know the condition of your valves... head gasket... or piston rings.. do a leakdown test my friend.
Kammy_Teg
Oct 11, 2008 02:14 PM
CrazyHondaBoy
Sep 16, 2003 10:13 PM
Rydaddy
Dec 10, 2002 07:17 AM
ionic_slim
Jun 3, 2002 05:14 AM
