question about tps voltage...
Old Aug 19, 2002 | 10:05 PM
Jockobo's Avatar
Default question about tps voltage...
do i check the volts when the engine running or do i just turn the ignition on??? its suppose to be .500 rite???
Old Aug 19, 2002 | 10:11 PM
sgT's Avatar
sgT
Default Re: question about tps voltage... (Jockobo)
you need the ignitoin on, engine running or not, doesnt matter.
should be .45 closed and around 4.5 fully open.
Old Aug 20, 2002 | 12:03 PM
Jockobo's Avatar
Default Re: question about tps voltage... (sgT)
but the volt changes when i turn the engine on
Old Aug 20, 2002 | 12:37 PM
Perfectionist's Avatar
Don't know what engine you've got, but it would make sense that the voltage changes. On my '90 Si there is a vacuum diaghram that holds the throttle open slightly to aid in starting. Once running, the engine supplies vacuum and pulls the diaghram free of the throttle linkage.
Old Aug 20, 2002 | 12:57 PM
Doctor CorteZ's Avatar
key on
or
ENGINE running ?
Old Aug 20, 2002 | 05:42 PM
Jockobo's Avatar
Default Re: question about tps voltage... (Doctor CorteZ)
engine running
Old Aug 20, 2002 | 06:16 PM
88_SC_CRX_Si's Avatar
New User
See if this helps any...
http://www.geocities.com/chipman_13/...shoot.html#TPS
Old Aug 22, 2002 | 10:30 PM
ef civic's Avatar
Default Re: question about tps voltage... (88_SC_CRX_Si)
this might sound stupid but when you check the tps with a volt meter, were do you put the probes if the tps plug is hooked up to the tps............... and please don't tell me i should put the probes up my ***....lol
Old Aug 23, 2002 | 12:14 AM
SoulSurfer's Avatar
Default Re: question about tps voltage... (ef civic)
We're putting new cover sheets on all our TPS reports.
Old Aug 23, 2002 | 05:36 AM
ef civic's Avatar
Default Re: question about tps voltage... (LSDelSol)
did you get the memo?
Old Aug 24, 2002 | 04:14 AM
SoulSurfer's Avatar
I got the memo. I've got it right here. I just forgot.
Old Aug 25, 2002 | 08:33 PM
ef civic's Avatar
anyone else????
and LSDelSol i'll make sure you get another memo
Old Aug 28, 2002 | 09:39 PM
ef civic's Avatar
bump
Old Aug 29, 2002 | 06:46 AM
read voltage from the center wire , ground the meter and pierce the wire on the TPS with it plugged in and the key on
Old Sep 7, 2002 | 09:56 PM
ef civic's Avatar
thanks for the info doc!
BABY NSX
Jun 10, 2013 05:16 PM
petrv
Sep 22, 2006 09:33 AM
Jaskula1
May 28, 2004 10:10 PM
ImportRacing
Nov 3, 2002 09:04 PM
98R-1144
Oct 7, 2002 11:28 AM
