Question about Oversized/Overbore ITR Pistons...
Old Nov 20, 2002 | 01:41 PM
Bigjussin's Avatar
Default Question about Oversized/Overbore ITR Pistons...
Hi there, i keep seeing these "Overbore" pistons....slated to be .025 overbore, does this translate to an 81.5mm bore on the sleeve? I am in need of help, would these raise the comp. levels to a reasonable level to run on pump gas?
Old Nov 20, 2002 | 02:20 PM
Colin's Avatar
Default Re: Question about Oversized/Overbore ITR Pistons... (bigjussin)
standard oversize is 0.25 of a mm larger. thus 81.25mm
the itr pistons will yeild different compression ratios in different motors. but as long as the head isn't milled and the head gasket is stock i can't think of a motor that would have too high of compression for pump gas if you used the itr pistons.
having oversized also raises the compression a little bit...but when i say little, i mean little. nothing to be concerned about.
blackeg
21
Jan 4, 2012 04:16 PM
Siberian Husky
Sep 23, 2005 05:58 AM
OH_SNAP10k_SHIFT!
12
Jul 27, 2005 06:08 PM
MOTOR R
Nov 26, 2001 03:29 PM
