Question about ls vtec
Old Jan 7, 2015 | 10:43 AM
Cheesey potato's Avatar
Default Question about ls vtec
I have a b18c1 and a b18b1, now everyone's saying run ls vtec. My question is what's the actual difference between doing that instead of just swapping the whole gsr motor? I know the b1 has a bigger displacement but couldn't I just run the crank in that, in the gsr motor?
Old Jan 7, 2015 | 01:12 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Question about ls vtec
More headaches when not done correctly.
Old Jan 9, 2015 | 04:55 PM
blackeg's Avatar
you can certainly run the b1 crank in the c1 motor. you will need the b1 rods with arp replacement rod studs and some pistons. you can run ls pistons, b16 pistons and i think itr pistons without modifications to the rod. i know for a fact that gsr pistons need to have work done on the connecting rod to fit. once you do that, you need b1 or b16 rod bearings. all the b series use the same main bearings. its doable for sure but if you dont really have experience inside a motor like marc said it could be more trouble than its worth
if you have both motors and they are in working order, just use the c1 engine, and maybe sell the b1 engine for some cash for mods and a tune
Old Jan 11, 2015 | 04:55 AM
blackeg's Avatar
oh ya, if you use the ls crank in a b18c block you have to plug the oil squirters too
Old Jan 11, 2015 | 10:51 PM
MOE@Hyper16Valve's Avatar
Icon6 Re: Question about ls vtec
You really DON'T have to, they can be bent and cut down some to work, I've done it.
But then again , QUOTE ( its doable for sure but if you dont really have experience inside a motor like marc said it could be more trouble than its worth).
Old Jan 12, 2015 | 05:48 AM
Thanks guys, it'll be easier for me anyways since I've already swapped a couple gsr before, I was only asking for more knowledge I guess haha
Old Jan 12, 2015 | 01:58 PM
The Grumpiest
Swapping is not the same as converting an engine to an LS/VTEC configuration. Not by a longshot. Have you actually read any of the DIYs out there on how to do it? I wouldn't attempt it.
Old Jan 12, 2015 | 02:24 PM
turbohatch96y7's Avatar
Lsvtec is easy to do
Plug the head
Insert dowels
Change pump and timing belt
Add hose to head from sandwich plate
Wheres the hard part?
Old Jan 12, 2015 | 02:25 PM
Now that ive read your post
Stick with the gsr
Old Jan 12, 2015 | 03:22 PM
The Grumpiest
Plug the head
Insert dowels
Not what I've read. Most, if not all of these things I've read up on require some internals being swapped as well as milling. And let's not forget tuning since this is a combo for which there is no stock basemap for. For example...
LS / VTEC : BASICS OF BUILDING ONE - Team Integra Forums - Team Integra
So my question is, If it is that easy then why the hell are people having such an issue getting one done properly?
If I'm wrong then by all means clarify so that there won't be any more jacked up "New LS/VTEC swap but my **** is all fucked up and won't run" threads.
Old Jan 12, 2015 | 10:08 PM
Originally Posted by grumblemarc
Not what I've read. Most, if not all of these things I've read up on require some internals being swapped as well as milling. And let's not forget tuning since this is a combo for which there is no stock basemap for. For example... LS / VTEC : BASICS OF BUILDING ONE - Team Integra Forums - Team Integra So my question is, If it is that easy then why the hell are people having such an issue getting one done properly? If I'm wrong then by all means clarify so that there won't be any more jacked up "New LS/VTEC swap but my **** is all fucked up and won't run" threads.
Im personally running a high comp b20 with phk pistons and a gsr head
Pretty straight forward
Ive always ran straight up gsr motors.
This b20v with 18g is by far the best.
I made 370whp on the gsr in its prime but all the low end tq on this b20v is enough to keep me smiling with the rev limiter set at 5k rpms
And its exactly straight forward how i described above
Old Jan 13, 2015 | 02:24 PM
The Grumpiest
Is the ease at which a B20VTEC can be assembled comparable for the LS motor with VTEC head? Everything I've read says otherwise.
Old Jan 13, 2015 | 04:54 PM
What did you read?
Same blocks bigger bore thinner sleeves
Tap the head insert plug pretty sure its a 1/8th npt hex head
Add sandwich plate
Add hose to feed oil to head
Gsr timing belt
Gsr water pump
Use the gasket that goes to the block
Thats pretty much it
I dont really know where your saying the hard part is
Nothing else is involved. If you're scared to tap the head have any other person that knows how to use a tap do it.
Old Jan 14, 2015 | 12:23 PM
The Grumpiest
The guides I read, which include this one https://honda-tech.com/all-motor-nat...0vtec-1676914/ all mention modifying the stock internals due to the LS pistons being garbage. All I ever se is people trying to use any piston they can and run into clearance problems. Then to top it off, this is a combo never offered by Honda so a tune is most definitely required. Another big problem I see posted is that no one gets tuned and tried to run whatever B-0series ECU that they can get their hands on. That isn't in your list.
So it may be straight forward as you describe it when it comes to the parts list, but there are all these people that can't seem to follow even the simplest of directions.
Glove
Feb 2, 2010 03:33 AM
projectstacy
Dec 4, 2007 09:49 AM
MessGSR
Jan 15, 2006 02:59 PM
Finger Lickin' good
Aug 18, 2005 06:49 PM
J-Spec EG
11
Oct 30, 2004 09:14 AM
