Q: over heating .... can it lean to warp head ????
Old Jul 8, 2007 | 02:05 PM
Charlie Moua's Avatar
Default Q: over heating .... can it lean to warp head ????
This is more of a overheating issue on my EF b18c, stock motor, OEM thermostat, stock ef radiator & fan.
My car is in storage and I only start it up 1-2 every 6months.
One time I started the car and let her idle for 10-20mins and after coming back the temp needle was all the way up.
I thought it may have just been a "defective thermostat" that was stuck closed.
I replaced it and it still overheats after about 10mins of driving or even while idling from cold start to 10mins.
<FONT COLOR="green">
Q: I'm about to replace my HG, by question is, how do I know if I have a warped gsr head? ..... if it is warped how do I fix it?
</FONT>
Old Jul 8, 2007 | 02:18 PM
yanksox's Avatar
Default Re: Q: over heating .... can it lean to warp head ???? (Charlie Moua)
Check your oil....see if your coolant and oil are mixing. If so then your head is warped, unless you messed up a hose. But that could be your problem. If it is warped you just pull it off and bring it to a machine shop and have them re-surface it. It costs like $75 at the machine shop by me.
Old Jul 8, 2007 | 02:27 PM
Default Re: Q: over heating .... can it lean to warp head ???? (yanksox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yanksox &raquo;</TD></TR><TR><TD CLASS="quote">Check your oil....see if your coolant and oil are mixing. If so then your head is warped, unless you messed up a hose. But that could be your problem. If it is warped you just pull it off and bring it to a machine shop and have them re-surface it. It costs like $75 at the machine shop by me.</TD></TR></TABLE>
I will do that next weekend....(replace oil to see if they are mixing)
other than that, I don't even see white smog from the tail pipe.... she still sounds like a champ, no sputter or weird idle at all...
Old Jul 9, 2007 | 08:36 PM
ej8's Avatar
ej8
After you confirm that you don't have a warped head or blown HG (recommend a compression check) - FLUSH your coolant. I had an overheating problem that was resolved by doing a chemical coolant flush (got at advance auto)
03EM2guy
Sep 14, 2010 07:40 PM
dc2_916
Dec 8, 2009 03:09 PM
h-o-n-d-a
22
Jun 19, 2009 07:22 PM
hondamike89
Feb 28, 2009 01:40 PM
AllAboutSleepers
Jul 7, 2008 04:11 PM
