Problems with JDM b20b swap (help)
Old Nov 10, 2014 | 10:47 AM
  #26
hybridmiklo's Avatar
Default Re: Problems with JDM b20b swap (help)
now you go back to basics again. Unplug the tps sensor. with the ignition in the on position make sure you get 5 volts. Then while the car is off do a voltage drop from the ground pin on the tps sensor plug and ground. If they both turn out good then replace the tps sensor. Just because its new doesnt mean it cant be bad.
ttsupra98
Dec 31, 2012 02:27 PM
Rukusmasta2
Jul 26, 2008 01:16 AM
90efmexstyle
Jun 25, 2008 07:44 PM
cjames235
Feb 2, 2002 07:50 PM
Kamin
Jan 9, 2002 11:21 AM
