Problems with B16A2 tranny..
Old Oct 19, 2003 | 01:43 AM
SOHC_DK.'s Avatar
Default Problems with B16A2 tranny..
I have a B16A2 with the original transmission on it.
When I bought the car there was a small problem when i was shifting near the redline, it grinded in 3rd og 4. gear, but i changed the oil with a Teflon additive and som Dexron II oil and now it runs clean and smooth.
But: When the car are left over night and I get out in the morning to start up, I simply cant get it into any of the gears, .. then somehow revers seems to be the easiest to get in, but from 1.-5. gear it wont snap in.. Then after 1-2 minutes of yelling in the car it gets in 1st. with a "klonk"-noise.. and after that there is no problem shifting.. sometimes it helps to drive around in reverse like 30 seconds, and then it just snaps in 1st. gear just like it should..
What could be wrong,, ?? Could it be a bad clutch??
M. Nielsen, Denmark
Old Oct 19, 2003 | 04:45 AM
mathusala's Avatar
Default Re: Problems with B16A2 tranny.. (SOHC_DK.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_DK. &raquo;</TD></TR><TR><TD CLASS="quote"> ...oil with a Teflon additive and som Dexron II oil...
M. Nielsen, Denmark</TD></TR></TABLE>
get the goo out of your tranny, change it to Honda MTF - run a tank of gas through it and then change it again
Old Oct 19, 2003 | 10:24 AM
SOHC_DK.'s Avatar
Default Re: Problems with B16A2 tranny.. (mathusala)
Well I started with changing to Honda MTF II but that did not make any difference (3000Km.) so I tried The Additive, and it actually helped...
M. Nielsen
Old Oct 19, 2003 | 01:50 PM
civickiller's Avatar
gm syncromesh friction modified
Old Oct 19, 2003 | 04:02 PM
mmuller's Avatar
Mad Scientist
Default Re: Problems with B16A2 tranny.. (civickiller)
yeah, its most likely the tranny fluid that you're using
20ls01
May 5, 2007 06:33 PM
jdmjunkieXL
27
Feb 22, 2007 09:24 AM
old_school_dohcvtec
Nov 20, 2004 04:13 PM
tyflip2
Nov 10, 2003 09:52 PM
int3gra
Oct 9, 2001 05:51 PM
