problem with arp rod bolts
Old Jan 23, 2009 | 07:22 AM
GSR615's Avatar
Default problem with arp rod bolts
also can anybody tell what i should do.
when i was torquing the my rod bolts in the head snapped off.
my torque wrench was a 16 lbs.
and it just snap.
Old Jan 23, 2009 | 07:36 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: problem with arp rod bolts
You could get the rod repaired but it will be easier to get a new rod.
Old Jan 23, 2009 | 07:45 AM
GSR615's Avatar
there's nothing wrong with the rod but the problem is that the arp rod bolt snapped off when i was torquing it down ..
Old Jan 23, 2009 | 07:52 AM
unusual71's Avatar
although i find it very hard to believe that the bolt snapped at 16 lbs, there is not much you can do but replace the rod. IMO anything you do to save the rod will weaken it and will be just asking for trouble. Don't create a weak point in the bottom end of your motor maybe send the rod to ARP for study and try get something out of them
Old Jan 23, 2009 | 07:57 AM
GSR615's Avatar
why would i neeed to change the rod ?
cant i just get new rod bolts ?
Old Jan 23, 2009 | 09:08 AM
mar778c's Avatar
Community Builder
You realize those rods are re-sized for the bolts. So if you remove bolts, the rod will have to be completely re-conditioned so you can use those bolts, if you can get an appropiate bolt. Thus, it would be a lot easier to buy a new rod.
Old Jan 23, 2009 | 09:12 AM
GSR615's Avatar
should i buy all new rods or just one ?
should i change all the rods bolts too ?
Old Jan 23, 2009 | 09:19 AM
batboyvaj's Avatar
y can't this guy just call up arp and ask for the same bolt? maybe you just got a bad batch
Old Jan 23, 2009 | 09:24 AM
GSR615's Avatar
i was going to do that but they said i should get new rods.
so i thinking bout its but i wanna know what i should do first b4 i do something
Old Jan 23, 2009 | 09:29 AM
usdmDC4's Avatar
Wow...yea id just buy new rod bolts if i were you
Old Jan 23, 2009 | 09:31 AM
mar778c's Avatar
Community Builder
Getting a bolt is no problem. Using the new bolt in a rod that already had arps could be a significant problem.
You have two options
(1) try to repair the current rod
(2) replace the rod
If it were me I would replace the rod. That is the almost full proof method for success. Repairing a rod can be a iffy proposition.
Old Jan 23, 2009 | 10:28 AM
GSR615's Avatar
(2) replace the rod
okay so should i change all the rods and rods bolts ?
Old Jan 23, 2009 | 10:48 AM
mar778c's Avatar
Community Builder
1st thing you should do is contact arp and see what they have to say about replacing the rods and rod bolts.
Also, you should torque check the rod bolts and ask what does arp recommend for the torque value.
Going forward, if ARP will not help you with the rods in any way then yes, I would replace all of them. If this is a GSR/type R then stock rod bolts are fine.
Old Jan 23, 2009 | 11:01 AM
kulo's Avatar
i have arp rod bolts
should i put them on my gsr
or just get arp head stud kit?
Old Jan 23, 2009 | 11:13 AM
GSR615's Avatar
no this is in a ls.
p3t3rxp4n
33
Feb 4, 2015 08:41 PM
rich7777
Mar 1, 2010 07:43 AM
Wazup
Mar 31, 2005 02:58 PM
TURBL0W
Dec 1, 2004 06:23 PM
FastFoot
Sep 28, 2002 12:09 AM
