Preloading the clutch
Old Oct 2, 2005 | 05:09 PM
biotech0123's Avatar
Default Preloading the clutch
Im confused on how this is properly accomplished, could someone explain this to with me. Ive done a search on this and came back with one topic that didnt answer my question..
Old Oct 3, 2005 | 04:02 PM
Default Re: Preloading the clutch (biotech0123)
anyone?
Old Oct 3, 2005 | 05:33 PM
drdisco69's Avatar
Are you talking about the clutches in an LSD? Those are about the only ones I can think of that you can preload.
Old Oct 3, 2005 | 05:36 PM
Sliced Beard's Avatar
Default Re: Preloading the clutch (drdisco69)
the only clutch that I can think of besides a differential type clutch that is preloadable is a drag clutch for a high horsepower car.
You are able to set preload, counter balance, initial clamping force, etc
please be more specific about what you are trying to ask
Old Oct 3, 2005 | 05:45 PM
drdisco69's Avatar
Default Re: Preloading the clutch (DirtySol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">You are able to set preload, counter balance, initial clamping force, etc</TD></TR></TABLE>
Ah, good point. Shows what I know about drag racing: zilch
Old Oct 3, 2005 | 09:03 PM
FalkenSiR's Avatar
I think the thread creator refers to let the clutch out slightly so that the car will creep forward, then pull the e-brake, set rpms at launch rpm, release clutch and launch. They do this to be easier on the axles as easy and to not spin that much off the line.
Note: All this is what I've heard.
Old Oct 8, 2005 | 07:28 PM
Default Re: Preloading the clutch (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">I think the thread creator refers to let the clutch out slightly so that the car will creep forward, then pull the e-brake, set rpms at launch rpm, release clutch and launch. They do this to be easier on the axles as easy and to not spin that much off the line.
Note: All this is what I've heard. </TD></TR></TABLE>
Thats what I mean, I dont know if its any diff with lsd though besides maybe both axles getting loaded before launching
hpi247
Jul 7, 2007 07:11 AM
EK FLY
May 24, 2007 03:45 AM
ic89
Oct 17, 2006 11:59 AM
carblegal
Dec 3, 2005 10:18 PM
Kellindal
Feb 28, 2002 11:17 AM
