PR3 ECU's (QUESTION)
Old Jan 8, 2002 | 02:14 PM
juicy.koreans.suck's Avatar
Default PR3 ECU's (QUESTION)
can someone please put up a picture of how the plugs go in(labeled) and the numbering of the pins so i can wire up my engine, thanks alot.
Old Jan 8, 2002 | 02:37 PM
marty's Avatar
Default Re: PR3 ECU's (88'CRIX)
88-91 JDM SiR
A1 #1 injector #1 injector
A2 Ground Ground
A3 #2 injector #2 injector
A4 Ground Ground VTEC solenoid
A5 #3 injector #3 injector
A6 Ground Ground
A7 #4 injector #4 injector
A8 VTEC solenoid none
A9 none none
A10 Pressure regulator cut-off solenoid valve Pressure regulator cut-off solenoid valve
A11 EACV EACV
A12 Main relay Main relay
A13 Main relay Main relay
A14 Main relay Main relay
A15 Main relay Main relay
A16 Ground Ground
A17 none none Secondary butterfly solenoid (IAB)
Only for GS-R B18C swaps - JDM B16A does not have IAB
A18 Ground Ground
A20 (5G wiring only) does not exist does not exist EVAP (red wire)
B1 Ignition switch Ignition switch
B2 none none
B3 A/C clutch relay A/C clutch relay
B4 none none
B5 VTEC pressure switch none
B6 Check engine light Check engine light
B7 none none
B8 A/C switch A/C swithch
B9 none none
B10 Crank angle sensor Crank angle sensor
B11 Traces to fuse box none
B12 Crank angle sensor Crank angle sensor
B13 Ignition switch Ignition switch
B14 Alternator Alternator
B15 Igniter Igniter
B16 Speed sensor Speed sensor
B17 Igniter Igniter
B18 none none
B19 Knock sensor P/S oil pressure switch
B20 Ignition timing adjusting connector Ignition timing adjusting connector
C1 Cylinder sensor Cylinder sensor
C2 Cylinder sensor Cylinder sensor
C3 TDC TDC
C4 TDC TDC
C5 Intake air temperature sensor (TA) Intake air temperature sensor (TA)
C6 TW sensor TW sensor
C7 Throttle angle sensor (T/A) Throttle angle sensor (T/A)
C8 O2 sensor none
C9 P/S oil pressure switch PA sensor
C10 Brake switch Brake switch
C11 MAP sensor MAP sensor
C12 Ignition timing adjusting connector Ignition timing adjusting connector
C13 T/A T/A
C14 MAP sensor MAP sensor
C15 MAP sensor MAP sensor
C16 O2 sensor O2 sensor
Old Jan 8, 2002 | 03:01 PM
Default Re: PR3 ECU's (MugenEF7)
hay man thanks for the list(sincerely) but i need the actual picture of the plugs pluggin in.
Old Jan 8, 2002 | 03:21 PM
iwhichisme's Avatar
yeah if you could i would like to see that too!
Old Jan 8, 2002 | 03:56 PM
Default Re: PR3 ECU's (iwhichisme)
please, rainforest, katman, someone knowledgeable....
Old Jan 8, 2002 | 04:55 PM
tinkerbell's Avatar
bottom ECU is PR3
http://www.geocities.com/b16aprelude/hondaengines.html
is how it plugs in...
they can only be pluged in one way? big clear plug in green socket, two smaller plugs in the black sockets.
is this what you wanted to know?
t..
[Modified by tinkerbell, 11:57 AM 1/9/2002]
Old Jan 8, 2002 | 04:59 PM
tinkerbell's Avatar
Default Re: PR3 ECU's (tinkerbell)
PS does anyone know if the PR3 ECU rev limiter is set at 8'100rpm?
does the PR3 have a rev limiter???
DualCamDan
Aug 10, 2004 05:46 AM
Honda_Tengoku
Mar 21, 2004 12:21 AM
HavokB18
Mar 19, 2004 05:50 PM
20lb.teg
Oct 17, 2003 07:19 PM
