powerwash a block?
Old Jul 24, 2004 | 02:50 PM
B18EG6's Avatar
Default powerwash a block?
i have a bare block, out of the car. Can I powerwash it? If so, what precautions should I take or things to tend to?
Old Jul 24, 2004 | 06:26 PM
civicsitek GanGsTa's Avatar
Default Re: powerwash a block? (B18EG6)
makes sure the main caps are off as well and power wash them seperately. Id use the soapy setting at your car wash. Apply some simple green, let it sit for a few minutes, wash and repeat. Then make sure you dry the block and parts thoroughly then apply some lube to the cylinder walls.
Old Jul 24, 2004 | 09:46 PM
SJcivic's Avatar
I would worry about forcing tiny particles of dirt/debris into the metal. So I'd have to say "ney" to this idea. Altho a steam clean would be an awesome idea to melt away the crud.
Rich
Old Jul 24, 2004 | 10:29 PM
B18EG6's Avatar
Default Re: powerwash a block? (SJcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJcivic &raquo;</TD></TR><TR><TD CLASS="quote">I would worry about forcing tiny particles of dirt/debris into the metal. So I'd have to say "ney" to this idea. Altho a steam clean would be an awesome idea to melt away the crud.
Rich
hmm interesting... can I steam clean with a powerwasher?
Old Jul 25, 2004 | 09:04 AM
B18EG6's Avatar
Also... Im no washing the cylinder walls haha... what if i block them off and just wash the outside?
Old Jul 27, 2004 | 05:03 AM
B18EG6's Avatar
okay one more time I guess... I dont want to take my block to the car wash... I have a powerwasher at my house, is this safe to use on the outside of the block and where the main seal goes?
Old Jul 27, 2004 | 12:12 PM
Yes, don't listen to what the other guy said, its misinformation. Spray some simple green on the block let it soak and wash it off. Even if you don't want to wash the cylinders after you dry the block you should lube them up with regular motor oil or another lube.
Old Jul 27, 2004 | 02:01 PM
B18EG6's Avatar
Default Re: powerwash a block? (civicsitek GanGsTa)
yeh but i can wash the simple green off with the powerwasher, righto?
Old Jul 28, 2004 | 09:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">yeh but i can wash the simple green off with the powerwasher, righto?</TD></TR></TABLE>
yes
Old Jul 28, 2004 | 09:19 AM
im_poor's Avatar
you can take it to a local machine shop and let them do it.
Old Jul 28, 2004 | 10:30 AM
B18EG6's Avatar
Default Re: powerwash a block? (im_poor)
i have a powerwasher myself, im finding alternatives to avoid the $50 tag that the machine shop charges.
If i were to wash the cylinders, wouldnt they rust? or just spray them with wd40 as soon as i dry them?
Old Jul 28, 2004 | 01:33 PM
im_poor's Avatar
it would rust if you left them sitting after you wash it, lube is with oil or wd40, and keep it away from moisture.
avotegra
Mar 11, 2008 06:24 AM
EK9Tune
14
Aug 18, 2007 10:07 PM
SOHC_me
Jan 13, 2007 07:40 AM
LUXXXX
Aug 16, 2006 08:16 PM
int3gra
Mar 2, 2004 10:02 PM
