post swap running hot
Old Jul 11, 2003 | 07:52 AM
Audipwr1's Avatar
Default post swap running hot
according to autometer gauge, shes around 190-200 f
b18b into a 91 dx hatch using the stock radiator
system was bled pretty well. Top rad hose is hot when car is warmed up
what is the target temp to run this motor at?
Old Jul 11, 2003 | 01:13 PM
Audipwr1's Avatar
Default Re: post swap running hot (Audipwr1)
eh
Old Jul 11, 2003 | 03:53 PM
No-Gi's Avatar
Check grounds. I had a friend who changed his rad, switch and thermo and the car was still hot and it ended up being a loose ground
Old Jul 11, 2003 | 04:02 PM
Patch's Avatar
Default Re: post swap running hot (3 South)
Make sure you have the right radiator cap and that its on tight. Check your top radiator hose AND your bottom hose are equally hot after you've been driving. Check and make sure your cooling fan is coming on.
Old Jul 11, 2003 | 04:05 PM
Audipwr1's Avatar
Default Re: post swap running hot (CRX PAT)
that is the temp with the fan hardwired and the heater on max
temps are equal on the two hoses
is that ef radiator not enough?
Old Jul 11, 2003 | 04:06 PM
Patch's Avatar
How old is the thermostat? When was the last time you flushed the radiator?
Old Jul 11, 2003 | 04:24 PM
Audipwr1's Avatar
radiator was flushed 120 miles ago when the motor went in
would the thermostat be stuck shut?
what is the target running temp of the b18b ?
Old Jul 11, 2003 | 05:06 PM
Patch's Avatar
Running temp should be at 160, if I'm not mistaken. I would definately change the thermostat.
Old Jul 11, 2003 | 06:54 PM
Audipwr1's Avatar
ive heard up to 220, anyone have a definate answer on this?
Old Jul 11, 2003 | 07:01 PM
CimorelliCRX's Avatar
Dont the thermostat open on a CRX at 180? So if thats the case, you give or take 5 degrees, and I think normal operating temp is 220-230.. I may be wrong, and I will check in a minute, but. What does your cluster temp gauge show? Normal operating temp?
Old Jul 12, 2003 | 04:23 AM
Audipwr1's Avatar
Default Re: post swap running hot (CimorelliCRX)
it was a little over normal before i removed it
fuglybutruns
Jul 28, 2015 07:50 PM
SlowB16
Feb 22, 2013 05:59 PM
chansta
15
Oct 12, 2010 02:29 PM
delsolnewkid
14
Feb 6, 2009 11:36 AM
spock_rocker
Jun 6, 2005 03:32 PM
