PLEASE help w/ front end problem on 95 hatch!!
Old Sep 30, 2003 | 07:33 PM
NickQ's Avatar
Default PLEASE HELP w/ front end problem on 95 hatch!!
Setup:
95 civic hatch
95 JDM GSR B18c
00 Integra Type R Tranny (LSD)
I developed this problem today driving home from work. There is something seriousley(sp?) wrong with something in the front, drivers hand side of the car. Under acceleration, either fast of slow, in any gear, the car is intermittidley pulling to the left every 1/4 of a second or so (left-left-left-left). And every couple of minutes it VERY quickley RIPS the steering wheel out of my hand to the left (left-left-left-left-LEFTRIP!). I jacked up the car and took off the wheels, and nothing seems to be loose. Both axles turn back and fourth a little, which i think is normal. I started the car on the jack stands and went through the gears. 1 through 4 there was a little noise in the tranny, and in 5th there was a loud noise like marbles in the tranny. But I do not know if the car being in the air had anything to do with that. (could have been the weight of the wheels, axles ect, in the air) So that is where I am. It is pretty much un-drivable. What do you think it might be. Let me know if there is any more info you need to know. PLEASE help. Any help is greatly appreciated!!!
Old Sep 30, 2003 | 08:00 PM
yellow eg's Avatar
Default Re: PLEASE HELP w/ front end problem on 95 hatch!! (NickQ)
the hatch has a problem with a plastic bushing in the stearing rack, tryto move the to control arms of the stearing rack if you feel a play while trying to move them verticaly( up and down) that might be your problem, do not know anything about that tranny noise tho
Old Sep 30, 2003 | 08:19 PM
NickQ's Avatar
Default Re: PLEASE HELP w/ front end problem on 95 hatch!! (yellow eg)
So do you think the noise I hear in the tranny has anything to do w/ the pull in the steering? I'm gonna jack it up tommorow and try to find a problem, so any info would be helpfull.
Old Sep 30, 2003 | 08:57 PM
RyanAutry's Avatar
I drove the car tonight.
Under light or heavy acceleration the steering wheel shakes left. When you let off the gas the klunking goes away. Then every once in a while the sterring wheel firmly turns left and the car swerves. But that's only ever once in a while.
We're thinking;
* Wheel Baring
* Bad CV Joint
* Bad LSD, but that doesn't sound correct.
* Bad Transmission, but that doesn't seem correct.
Old Sep 30, 2003 | 09:37 PM
cavakilla's Avatar
Default Re: PLEASE HELP w/ front end problem on 95 hatch!! (RyanAutry)
my opinion would be bad diff from your description, but check upper ball joints and upper control arm bushings.. good luck tom
Old Oct 1, 2003 | 07:10 AM
RyanAutry's Avatar
Default Re: PLEASE HELP w/ front end problem on 95 hatch!! (cavakilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cavakilla &raquo;</TD></TR><TR><TD CLASS="quote">my opinion would be bad diff from your description, but check upper ball joints and upper control arm bushings.. good luck tom</TD></TR></TABLE>
Thanks for the reply.
Old Oct 1, 2003 | 11:07 AM
kaj's Avatar
kaj
haha. he called you a tom LOL
Old Oct 1, 2003 | 11:09 AM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry &raquo;</TD></TR><TR><TD CLASS="quote">I drove the car tonight.
We're thinking;
* Wheel Baring
* Bad CV Joint
to clarify, in case it matters: no probs while decelerating. "Then every once in a while the sterring wheel firmly turns left and the car swerves. But that's only ever once in a while." &lt;--- this is while accelerating ONLY.
Old Oct 1, 2003 | 04:29 PM
RyanAutry's Avatar
Default Re: PLEASE HELP w/ front end problem on 95 hatch!! (kaj)
Old Oct 1, 2003 | 10:07 PM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Oct 1, 2003 | 11:11 PM
Tofurky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cavakilla &raquo;</TD></TR><TR><TD CLASS="quote">my opinion would be bad diff from your description</TD></TR></TABLE>
i'm gonna agree with that.
Old Oct 2, 2003 | 12:26 PM
kaj's Avatar
kaj
Default Re: PLEASE HELP w/ front end problem on 95 hatch!! (Tofurky)
i was thinking diff as well.. then we thought cv joint.. but consensus says diff...
with all the power he'll have he doesn't want the stock LSD anyway, right?? *silver lining*
Old Oct 2, 2003 | 03:12 PM
NickQ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaj &raquo;</TD></TR><TR><TD CLASS="quote">with all the power he'll have he doesn't want the stock LSD anyway, right?? *silver lining*</TD></TR></TABLE>
I know, I dont think the stock lsd will handle 900whp.
Old Oct 2, 2003 | 05:48 PM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NickQ &raquo;</TD></TR><TR><TD CLASS="quote">
I know, I dont think the stock lsd will handle 900whp. </TD></TR></TABLE>
i thought you were going for 910?? 900 is NOTHING!
Old Oct 2, 2003 | 06:11 PM
NickQ's Avatar
Damn, caught me. I wasn't gonna tell you, but I decided not to go for the 910. Gonna try and keep it down around the 900 range.
Old Oct 2, 2003 | 07:46 PM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NickQ &raquo;</TD></TR><TR><TD CLASS="quote">Damn, caught me. I wasn't gonna tell you, but I decided not to go for the 910. Gonna try and keep it down around the 900 range. </TD></TR></TABLE>
it's good to be reasonable.. just think of all the mods you'll have to do to handle the 910!!!!
Old Oct 2, 2003 | 08:04 PM
NickQ's Avatar
I know. With 900, all I'll prob need is, like, a cold air intake, but 910. You're talkin' that PLUS 100 octane gas.
Old Oct 3, 2003 | 09:52 AM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NickQ &raquo;</TD></TR><TR><TD CLASS="quote">I know. With 900, all I'll prob need is, like, a cold air intake, but 910. You're talkin' that PLUS 100 octane gas.</TD></TR></TABLE>
yeah... and the damned fart pipe.. it's just too much trouble.
Old Oct 3, 2003 | 05:15 PM
NickQ's Avatar
:werd:
Old Oct 4, 2003 | 02:24 AM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NickQ &raquo;</TD></TR><TR><TD CLASS="quote">:werd:</TD></TR></TABLE>
this ain't mustang world hahaha
Old Oct 4, 2003 | 08:29 AM
NickQ's Avatar
:glenn:
Old Oct 4, 2003 | 02:03 PM
kaj's Avatar
kaj
:greddy:
Old Oct 5, 2003 | 08:12 PM
NickQ's Avatar
It was the axle. Replaced it, works now. Thanks for the help Ryan, Jason, and Robert.
Old Oct 6, 2003 | 03:10 AM
kaj's Avatar
kaj
you guys should ALWAYS listen to me first.. my first guess: cv joint (close enought to axle ).. second: differential..
HA! i'm teh win
91integraLSVTEC
Suspension & Brakes
Dec 28, 2010 12:47 PM
allshownogo
14
Sep 22, 2009 09:33 AM
88 civic ef
Jul 18, 2006 02:08 AM
NickQ
Oct 4, 2003 12:36 AM
cash459
Mar 28, 2003 04:27 AM
