plastigauge - how the hell does it work
Old May 16, 2003 | 02:13 PM
Greyout's Avatar
Default plastigauge - how the hell does it work
never seen it, don't know where to stick it. Can't imagine being able to check bearing clearances when the motor is assembled.
can someone explain it, or point out some good online resources on how to use it.
Old May 16, 2003 | 02:48 PM
Dokta's Avatar
Default Re: plastigauge - how the hell does it work (JDM LUDE)
They have two different kinds. The plastic stuff, and the lead stuff. They both work exactly the same. You take a strip of it and lay it on a bearing surface, say for example your crank bearings. Then with the piece of plastigage still on the surface, you replace the crank and the bearing caps, reinstall everthing and torque it down to spec. Then take it all apart and look at how wide the thing was squished. Compare it to a chart that is given, and that gives you the bearing clearance. This is done because its impossible to fit a feeler gauge onto a bearing surface.
Old May 16, 2003 | 04:49 PM
P1mpSlap's Avatar
Good info. I totally did not know that!
Old May 16, 2003 | 06:19 PM
4DeepCivic's Avatar
Default Re: (P1mpSlap)
make sure the surface is clean as hell.. my $.02
Old May 16, 2003 | 10:23 PM
3rdGteg's Avatar
Default Re: (4DeepCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DeepCivic &raquo;</TD></TR><TR><TD CLASS="quote">make sure the surface is clean as hell.. my $.02</TD></TR></TABLE>
Old May 17, 2003 | 02:42 AM
EKFerioHawaii's Avatar
Default Re: (3rdGteg)
Bump to the tizzle for peeps who dunno.
Old May 17, 2003 | 06:28 AM
cjohnson_2's Avatar
Default Re: (EKFerioHawaii)
Its really simple once you figure it out. Its pretty cool a little piece the thickness of dental floss will tell you so much. you just have to have an eye for matching up the thickness when your done.
dallasyoung
Nov 2, 2011 04:53 PM
Dat1BVtecN
Feb 1, 2007 07:33 PM
Touge Tuning
Oct 22, 2006 01:03 PM
petrv
Aug 9, 2004 12:26 PM
raser5050
Aug 6, 2004 07:58 AM
