Plastigage for Connecting Rods
Old Aug 7, 2003 | 02:58 AM
zCivic's Avatar
Default Plastigage for Connecting Rods
Ok I tried to plastigage my rods last night with .001-.003 plastigage. The problem is my clearances are way out of spec. I was wondering seeing the specs range from .0008-.0015 if the gage I have is for too large of a clearance. When I checked them it was at about .0016 or .0017. I know the orginal bearing were brown and I'm using ACL std bearings. The orginal bearing showed little to no wear so they should still be with in specs. I had the crank micro polished and the big end of the connecting rod checked. The machine shop didn't say anything about needing oversized bearings or doing anything to make either that much larger. Any help you can offer is great and appreciated. TIA
Old Aug 7, 2003 | 03:41 AM
sgT's Avatar
sgT
Default Re: Plastigage for Connecting Rods (zCivic)
if you are getting .0016-.0017" you should be fine.
Old Aug 7, 2003 | 05:18 AM
zCivic's Avatar
Default Re: Plastigage for Connecting Rods (sgT)
Ok I was just wondering b/c the Honda svc manual for the B18s say its .0008 to .0015. I have looked at the B16 svc manual and it says the service limit was .0015 and a chiltons says .0020. So would it be the same srv limit of .0020 for the connecting rods is that why .0017 is going to be safe. Its a ls-vtec and will be draged some to 8200 rev limit but not autox so it wouldn't be held at high RPM for very long. Its also a daily driver.
Old Aug 7, 2003 | 05:43 AM
sgT's Avatar
sgT
helm should list service limit at .002
Old Aug 7, 2003 | 05:50 AM
zCivic's Avatar
ok thanks just wanted to make sure that .002 was the accual svc limit and not the .0015. guess gonna make sure 1 more time then get ready to get it together.
PyroProblem
Engine Machining & Assembly
23
Nov 1, 2015 07:37 AM
turbotypeR@SPEC
Jan 4, 2012 10:25 AM
90ZCREX
Sep 3, 2011 11:47 PM
arc_55
Jun 28, 2011 04:56 AM
Mutiny1
Feb 13, 2010 04:26 PM
