Rod bearing clearances too tight!!
Old Sep 3, 2011 | 11:31 AM
90ZCREX's Avatar
Default Rod bearing clearances too tight!!
Heres the setup:
a6 block
y8 head
eagle rods
vitara pistons
acl race bearings
bored to 75.5mm
I'm assembling the shortblock right now and checking bearing clearances with plastigauge. Main bearing clearances look all good at around .0017-.0018.
But all the rod bearings are measuring out at a little less than .001 looks like about .0007-.0008. Way too tight right?
So I guess I'm gonna have to go with oem bearings for the rods,
Can anyone help me figure out which bearings I'm gonna need?
The acl's are supposed to be standard which are green correct?
Old Sep 3, 2011 | 11:41 AM
rich7777's Avatar
Default Re: Rod bearing clearances too tight!!
I'd just take the rods to a machine shop and get them resized using those bearings. I'm not sure if you'll be able to hit a sensible clearence using the smallest honda bearing.
Old Sep 3, 2011 | 11:55 AM
90ZCREX's Avatar
Why would the clearances be out this much? Rods machined wrong?
Old Sep 3, 2011 | 01:36 PM
90ZCREX's Avatar
I plastigauged a different set of fj rods on the crank and I'm right at .001 clearance. Can a machine shop take some material off the crank? Like .001 so that would put my clearances to . 0018 or .0019? or should I just get the rods bored out a little?
Old Sep 3, 2011 | 04:10 PM
bigsnorlax's Avatar
Get the rods to a machine shop for a light hone to your specs. IMO dont fool with those stock cranks unless you REALLY have to.
Old Sep 3, 2011 | 05:00 PM
90ZCREX's Avatar
Well, I've been looking around on the net and I've found the acl hx bearings which are supposed to be .001 thinner to give you that much more clearance. These would put me right at .0018 or so. I think I'll try them before I pull the rods back out.
Old Sep 3, 2011 | 05:12 PM
shanebadoo's Avatar
Exactly what I did. got the hx acl bearings and clearances were much better.
Old Sep 3, 2011 | 11:47 PM
rich7777's Avatar
Yep & maybe the crank journal sizes. You could try those other acl bearings if you wanted.
dieselwilly
Honda Civic (2001 - 2005)
Nov 23, 2014 03:20 PM
cjonescrx
10
Aug 2, 2012 04:41 AM
SlowPokeEg
Feb 29, 2012 09:08 AM
y7turbo
Nov 1, 2007 08:21 PM
nkymain
11
Sep 22, 2005 01:25 PM
