Planning to lower car - how to jack it up?
Old Apr 16, 2002 | 10:22 AM
!!Mark!!'s Avatar
Default Planning to lower car - how to jack it up?
Hey everyone, I just found this board and it looks far better than clubsi.com .
I am thinking about lowering my car with coilovers, but I am concerned about jacking the car up for oil changes (at home) and changing tires. I predicted what the ground clearance would be after the desired drop height, and I found that the front of my jack will not even fit under the car... I could buy new low jack, but I'd like to see other options.
Any input would be appreciated, thanks.
Old Apr 16, 2002 | 10:23 AM
!!Mark!!'s Avatar
Default Re: Planning to lower car - how to jack it up? (Mark)
My other concern - what if you have a flat tire in the middle of a highway - can you change the wheels yourself or must you call in a tow truck?
Old Apr 16, 2002 | 10:24 AM
mercury's Avatar
New User
Drive your car onto some wooden planks or anything else to give you that extra bit of height. Then you'll be able to fit your normal jack underneath it.
Old Apr 16, 2002 | 10:25 AM
!!Mark!!'s Avatar
Default Re: Planning to lower car - how to jack it up? (mercury)
So I should buy some 2x4's and build mini-steps to drive on? Thanks not a bad idea, any others?
Old Apr 16, 2002 | 11:03 AM
Safir's Avatar
we do it one of two ways... if it's close, use some brut force and lift the car up a little to squeeze the jack under, or drive up on some wood pieces.
as for changing a flat, if your car is so low the scissor jack that comes with teh car won't fit under it then i don't knwo what to tell you...
Old Apr 16, 2002 | 02:46 PM
BoM's Avatar
BoM
Default Re: Planning to lower car - how to jack it up? (Safir)
i used to pick up the car's front just a tad
to slide the lift under.
Old Apr 16, 2002 | 03:28 PM
96 SOHC VTEC's Avatar
Default Re: Planning to lower car - how to jack it up? (BoM)
You jack won't fit under it? My stock jack fits under my lowered Civic fine, even when I had it dropped 3.5" it still fit. Took a hell of a lot turns to get it up in the air, but it still worked.
Old Apr 16, 2002 | 04:03 PM
Greyout's Avatar
Default Re: Planning to lower car - how to jack it up? (96 SOHC VTEC)
my jack fits under my prelude thats lowered 2" w/ wingswest sideskirts.
my floor jack, however, does not fit under the front lip. I either lay a few planks of wood down and drive up onto them or just stick the factory jack under the side, raise it up just a bit, and then slide the floor jack in from the front.
Old Apr 19, 2002 | 12:37 PM
PupaScoopa's Avatar
Default Re: Planning to lower car - how to jack it up? (JDM LUDE)
Waaaaa?? Brute force, why bother? Use a 2x4, a pipe or something and use it to lever the car up enough to get the jack underneath. Use some simple machines to make life easy.
[Modified by PupaScoopa, 9:38 PM 4/19/2002]
RiceRacist
12
Oct 11, 2003 08:03 AM
nijia555
37
Aug 11, 2003 08:05 PM
216.226.142.95:27016
Apr 7, 2003 04:48 AM
Darren94ls
Jul 13, 2001 03:05 AM
