piston rings...help me out..
Old Jan 26, 2005 | 06:40 PM
mr. vang's Avatar
Default piston rings...help me out..
okay.just bought a b18b cheap from a guy.he was saying that the motor had a blown head gasket or some sort cause it wouldnt hold compression.took the motor apart and the head gasket seems okay.got new one.took the whole motor apart pistons and all.was wonderin if i can use the old piston rings. will it still hold compression.thanks.
Old Jan 26, 2005 | 07:22 PM
mr. vang's Avatar
Default Re: piston rings...help me out.. (jdm_whore)
ttt
Old Jan 26, 2005 | 07:59 PM
T4eg's Avatar
I would replace the rings. Their is no point to put the old ones back in if u got them out did all the ringlands on the pistons look good? how does the head look? Was the motor "in time"? Just a few other areas to look
Chris
Old Jan 26, 2005 | 08:36 PM
mmuller's Avatar
Mad Scientist
you might be able to get away with re-using the piston rings if you keep them in the same exact order they came out.
but still pointless if you ask me...rinds and bearings are not all that much and you'll pretty much have a rebuilt bottom end
Old Jan 26, 2005 | 10:18 PM
mr. vang's Avatar
Default Re: piston rings...help me out.. (BlueHatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">I would replace the rings. Their is no point to put the old ones back in if u got them out did all the ringlands on the pistons look good? how does the head look? Was the motor "in time"? Just a few other areas to look
Chris</TD></TR></TABLE>
ringlands are find...the head looked fine..valvetrain looked fine...
Old Jan 26, 2005 | 10:19 PM
mr. vang's Avatar
Default Re: piston rings...help me out.. (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you might be able to get away with re-using the piston rings if you keep them in the same exact order they came out.
but still pointless if you ask me...rinds and bearings are not all that much and you'll pretty much have a rebuilt bottom end</TD></TR></TABLE>
i havent taken the rings off the piston yet...well i got new rod bearing and main bearings...
Old Jan 26, 2005 | 11:11 PM
clayne's Avatar
Do NOT re-use the rings.
New rings are rigid and the material is resistant to bending. Upon installation, using proper methods, they will present you with no issue.
Old rings are soft and malleable and can easily twist/bend/etc. damaging the bore on re-install if one is not cranking up the spring compressor to a high rate and aligning them perfectly.
Not to mention it's just a stupid idea anyways.
If you have all new bottom end bearings - it's time to bore .25 or .50 mm over and rehone - along with new pistons (that are .25 or .50 mm over). But at the minimum if reusing the old pistons with a fresh set of rings: I'd still have a machine shop check for trueness of bore and hone it if it's in spec.
Old Jan 27, 2005 | 06:13 AM
tgreaves's Avatar
Default Re: piston rings...help me out.. (clayne)
You can get a set of hasting rings for $45 shipped from hasting.. Why put the engine all back together and have the same problem again..
Old Jan 27, 2005 | 05:40 PM
PrettyLude's Avatar
45 bucks for some rings, or a big headache later?
that's an easy one
Old Jan 27, 2005 | 07:55 PM
VRD^don's Avatar
Default Re: piston rings...help me out.. (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">You can get a set of hasting rings for $45 shipped from hasting.. Why put the engine all back together and have the same problem again..</TD></TR></TABLE>
ooo..sounds good..got a link
Old Jan 27, 2005 | 09:57 PM
PrettyLude's Avatar
http://www.hastingsmfg.com/
r3v da t3g
Oct 30, 2007 04:50 PM
turbo1.8
May 29, 2007 01:05 PM
4gencivicef9
Jun 27, 2006 05:51 PM
law_teg_92_R
Aug 11, 2005 04:28 PM
60-1
Dec 8, 2003 07:46 AM
