Piston ring gap (WISECO)
Old Apr 26, 2007 | 06:46 PM
b20vtech's Avatar
Default Piston ring gap (WISECO)
wanted to know what ring gap clearence u guys are running with wiseco pistons.. or what wiseco reconmends.... im using the 84.5mm 13cr skirt coated ones...
1st ring gap clearence??
2nd ring gap clearence??
and oil/spacer??
thanks in advanced
Old Apr 27, 2007 | 01:22 PM
frostyrb's Avatar
Default Re: Piston ring gap (b20vtech)
I think it is .015 for both comp rings, & you can leave the oil control rings alone.
Old Apr 28, 2007 | 10:07 AM
b20vtech's Avatar
Default Re: Piston ring gap (frostyrb)
is this from your experience or ur getting it from wiseco?? need more info
Old Apr 28, 2007 | 01:06 PM
NJIN BUILDR's Avatar
https://honda-tech.com/zerothread?id=1442068
Old Apr 29, 2007 | 06:45 AM
frostyrb's Avatar
Default Re: Piston ring gap (NJIN BUILDR)
Direct from wiseco .004" per inch of bore for top & second rings. Additional end gap may be necessary for race or high performance applications.
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
Speedz
Nov 15, 2006 10:04 AM
mahatma
Apr 2, 2006 09:36 AM
riceball777
Jan 17, 2004 09:41 PM
non-VTEC
Oct 26, 2002 08:15 AM
