weisco piston ring installation.........
Old Oct 25, 2002 | 02:32 PM
non-VTEC's Avatar
Default weisco piston ring installation.........
i have a set of weisco piston rings that i purchased from Jeff at importbuilders.com
i can see the top and second rings have numbers/letters near the gap of the rings so those face upwards on the piston.
but the oil control rings have no marking on them at all. i asked Jeff and he told me there should be number/letters on the oil rings as well but there isnt.
could it be that the oil rings can be installed either way facing up or down? i cannot see any markings at all on the rings.............and they all look the same....
anyone else have this problem? does it matter which way i put these rings in?
any help would be appreciated.
thanks
Old Oct 25, 2002 | 05:49 PM
SiR Kid's Avatar
New User
Default Re: weisco piston ring installation......... (non-VTEC)
What's the part number of the rings.. I'm hearing a nasty rumor that Wiesco and JE are distributing low tension motorcycle style rings with their pistons.
If the last digits of the ringset is XC then they're low tension rings, get em swapped or for standard tension so you don't have to pull it apart after 10-15k miles!
FYI!
Old Oct 25, 2002 | 06:30 PM
Flamenco-T's Avatar
Default Re: weisco piston ring installation......... (SiR Kid)
the oil gap ring can be installed in both ways, only the primary and secondary rings are the one that can be install in one direction
stan
Old Oct 25, 2002 | 06:40 PM
1 2 NV's Avatar
FYI!
low tension rings seal well and make more HP than high tension rings. think of it as trying to pull 200lbs behind u. then try pulling 100lbs behind u. thats what low tension rings do vs high tension rings. the easier parts can move the more HP u can potentially make.
Old Oct 25, 2002 | 07:14 PM
non-VTEC's Avatar
Default Re: weisco piston ring installation......... (Flamenco-T)
the part number is XC 8450
i was told these are weisco high tension rings.............and jeff at import builders assured me they havent had any problems with them........so i'm hopeing these will work good........
Old Oct 25, 2002 | 08:22 PM
3rdGteg's Avatar
Yeah the oil control rings should be able to go either way like stock rings; just make sure the compression rings are upright though. How much are those wiseco rings btw?
[Modified by 3rdGteg, 5:23 AM 10/26/2002]
Old Oct 26, 2002 | 06:23 AM
non-VTEC's Avatar
Default Re: weisco piston ring installation......... (3rdGteg)
e-mail jeff at IB..his prices are pretty competitive......
Old Oct 26, 2002 | 08:15 AM
3rdGteg's Avatar
okay cool.
Boyle.R
Jun 21, 2014 12:38 AM
benin360
Nov 26, 2011 09:20 PM
riceball777
Jan 17, 2004 09:41 PM
Aeka GSR
Sep 28, 2003 11:15 AM
Islander
Oct 11, 2002 02:45 AM
