Piston Comp ratios?
Old Nov 21, 2001 | 10:18 PM
Weslay's Avatar
Default Piston Comp ratios?
Someone have the specs on ctr, itr, and del sol pistons placed in a B18C1? Which makes the higher comp ratio?
Old Nov 21, 2001 | 10:34 PM
Backyard Speical's Avatar
Default Re: Piston Comp ratios? (Weslay)
after you deck the block to zero clearance with the ITR you should have about 11.8-12.3 compression ratio with the GSR head. CTR would be a 12.0-12.5. and B16A would be about 11-11.5
Bedgoodmrb
Dec 20, 2009 07:36 PM
Ruben19
Dec 30, 2005 08:02 AM
shomershavis
11
Sep 4, 2004 10:19 AM
duRritztiNy
35
May 16, 2003 10:36 PM
Ruby Civic
Sep 7, 2002 11:40 AM
