difference in CTR and ITR pistons
Old Dec 20, 2009 | 12:31 PM
Bedgoodmrb's Avatar
Icon2 difference in CTR and ITR pistons
what is the difference in the CTR pistons and the ITR pistons?
i'm in the market for buying some.
Old Dec 20, 2009 | 01:12 PM
jry2598's Avatar
Default Re: difference in CTR and ITR pistons
research for yourself...it'll save u alot of headaches. personally i chose ctr first and then sent them back for pr3 b16 piston....
Old Dec 20, 2009 | 01:37 PM
kchungb17a's Avatar
http://www.ff-squad.com/tech/temp/pistons.htm
Thanks again Katman.
FYI, CTR piston + P72 head + pump gas = blown up engine.
Old Dec 20, 2009 | 01:45 PM
Bedgoodmrb's Avatar
what would you say would work kchungb17a? for a 95 GSR head with 93 octane in it.
Old Dec 20, 2009 | 01:57 PM
S2Integra's Avatar
I Got B18C1 with PR3 pistons in the stock P72 Head. Great combo.
Old Dec 20, 2009 | 03:23 PM
Bedgoodmrb's Avatar
what is your compression ratio? how much horse power did you get? and did you do anything else to it?
Old Dec 20, 2009 | 03:57 PM
Bedgoodmrb's Avatar
i just did a compression ratio calculation. how does, a JDM ITR piston with a GSR rod, 1 layer of headgasket thickness with GSR block and GSR head w/ after market Ferrea valve train, sound to you all?
thats a 11.06:1 c/r
Old Dec 20, 2009 | 07:36 PM
kchungb17a's Avatar
What CR calc is giving you the 11.06:1? The CR calc I'm using shows 11.92 with the specs you gave (assuming 81mm bore and that the Ferrea valves do not change CR; the CR goes up with larger bore size).
My CR calculator:
http://www.ff-squad.com/technet/cr-calculator.htm (once again, thanks to Katman)
11.92 might be a bit too high for pump gas. Not impossible if you run a good custom ECU tune, but on a stock ECU, it might be iffy. Remember that the GSR P72 head has a smaller combustion chamber than the ITR/CTR/PR3 so the compression ratio will be higher than the ITR/CTR spec head.
If you're running a stock ECU and are just building a DD, then I'd recommend you err on the side of caution. That's what I did with my engine: USDM ITR spec piston, 81.25mm bore, stock 3 layer gasket in an otherwise B18C1 engine (approx 10.8:1). With CTR cams, it dyno'd at 165. Not bad. If you've got a tunable ECU, a good tune (emphasis on good) can accommodate a higher CR.
Ricextacy
29
Apr 20, 2009 10:53 PM
JDM Lyfestyle
Jan 31, 2009 05:51 PM
aintnothing
10
Jan 29, 2006 05:45 PM
jeremy.
199
Dec 23, 2004 03:45 PM
shomershavis
11
Sep 4, 2004 10:19 AM
