Peeps with OBD1 ECU's. Simple Question.
Old Nov 20, 2001 | 10:03 PM
HXMan's Avatar
Default Peeps with OBD1 ECU's. Simple Question.
When you get a CEL while driving, does it go away when you turn off your car and start it again?
Need to know, cuz mine does this.
Old Nov 20, 2001 | 10:59 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Peeps with OBD1 ECU's. Simple Question. (HXMan)
depends on the CEL.
Old Nov 21, 2001 | 08:56 AM
92sleepR's Avatar
New User
That would indicate an intermitent problem like a short or a loose connection. Check all the wiring and clean all the connector contact points. I was getting a CEL on the intake air temp sensor and cleaning the contacts got rid of it.
Mike
Old Nov 21, 2001 | 02:41 PM
fixhondas's Avatar
Yes- it will be out when you restart- If it is a hard failure the light will come on for a few seconds and go out for short instance and come back on.
Old Nov 21, 2001 | 06:28 PM
HXMan's Avatar
Default Re: Peeps with OBD1 ECU's. Simple Question. (fixhondas)
Thanks for the input...now I need a little more.
When I checked what was causing the CEL my CEL blinked once, really fast. Is this right? My OBD2 ECU would blink slowly for the first digit, and fast for the second. I am trying to figure out if this is a problem with my Hondata Unit or my car itself.
Sorry I have so many questions, but I don't have much experience with OBD1.
Old Nov 22, 2001 | 11:40 AM
HXMan's Avatar
Old Nov 22, 2001 | 03:47 PM
fixhondas's Avatar
It blinked 1 short blink? -this is an O2 code and it is a single digit code. If it was a double digit code, say 43, it would blink 4 long blinks and 3 short blinks.
Old Nov 22, 2001 | 08:22 PM
HXMan's Avatar
Yea, it blinked once really fast and that was it. I just replaced my O2 sensor with another used one, and I am still having the same bogging problem while my car is warming up...but that doesn't throw a code. Only when I slow down do I get a CEL....the funny thing is I took a 500 mile trip and I didn't get a CEL once.
Guess I will have to get a New O2 sensor.
[Modified by HXMan, 11:23 PM 11/22/2001]
sumoneEK
Nov 22, 2010 11:29 AM
buh_buh
Jul 27, 2006 03:11 AM
TRAG
Honda Civic (2006 - 2015)
Jun 20, 2006 09:07 PM
conesmasher
Oct 19, 2004 03:26 PM
