painting block for easy CLEANING
Well i'm really a perfectionist about keeping my investments in top noch condition.
This is NOT a question about making a "BLINK-Bling" block,..... it's about what can I do paint over the block so that i can CLEAN it with ease.
i was thinking about some sort of spray paint/coat that will still be look sliver but will make it much easyer for me to wipe off dirt & greases.
any options let me know
you could have it sand blasted and powder coated, but that only makes sense if it's already torn down to just the block.
[Modified by liquid51, 9:33 AM 3/17/2003]
Dupli-Color "cast coat gray" engine enamal is the closest paint color I have found that looks like a clean cast AL block.
[Modified by SLPR, 6:54 AM 3/17/2003]
-also how will sandblasting it help? i know it will clean it but will it make the surface smoother or somthing?
**powerdercoating a block is out of the question.
what about sanding/polishing the block? Smooter surface should be easier to clean off...of course then you'd have to do it really well or it'll look like ish
-will that cast coat spray make it smoother or less resiastant to dirt & grease?
You should use an Engine Enamal paint....any old regular spray paint would be a waste of your time. Remeber it will be exposed to heat and solvents during its life in your engine bay. Good luck
