p28 question
Old Nov 7, 2005 | 05:38 PM
jdmcoop's Avatar
Default p28 question
just wondering if you are able to still wire a knock sensor into the p28 ecu?
Old Nov 7, 2005 | 06:03 PM
SVOboy's Avatar
Don't think so, not completely sure though. I know that when I wrote a d16y8 map for a p28, I had to disable it.
Old Nov 7, 2005 | 07:10 PM
mtber's Avatar
Default Re: (SVOboy)
A p28 ecu does not have a knock board.
The honda knock sensor is useless in most cases
Old Nov 7, 2005 | 07:15 PM
SVOboy's Avatar
Ah, thanks for confirming that, ^_^
Old Nov 7, 2005 | 07:23 PM
rainforest's Avatar
but you can add a knock board if wanted
Old Nov 8, 2005 | 07:55 AM
drdisco69's Avatar
Default Re: (rainforest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">but you can add a knock board if wanted </TD></TR></TABLE>
Old Nov 8, 2005 | 11:43 AM
jdmcoop's Avatar
this may be a stupid question but where would i find one? just out of another ecu?
Old Nov 8, 2005 | 01:49 PM
93turbo16's Avatar
yep, P72 or P30 should work. But takes more than just soldering in the board.
Old Nov 8, 2005 | 02:43 PM
jdmcoop's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">yep, P72 or P30 should work. But takes more than just soldering in the board.</TD></TR></TABLE>
like adding the wire in the wiring clip and what else. sorry so many questions. the reason i don't want to change ecu's is because i already have mine socketed for hondata s300.
Old Nov 8, 2005 | 03:40 PM
93turbo16's Avatar
I would not even worry about using a knock board. Just get a knowledgable tuner behind it and you will be just fine.
Old Nov 8, 2005 | 06:49 PM
drdisco69's Avatar
Default Re: (sleeper-ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper-ek &raquo;</TD></TR><TR><TD CLASS="quote">like adding the wire in the wiring clip and what else.</TD></TR></TABLE>
You just need to use a program from a knock enabled ecu, like a P30.
Scotty B
Mar 26, 2021 03:15 PM
dkrex001
Oct 1, 2006 10:34 PM
civicjdmb16a
Sep 11, 2006 06:29 PM
SHG_EasyE
Jan 22, 2006 11:26 AM
snowblind7x
Aug 26, 2005 04:40 PM
