Oversize Piston?
Old Jan 23, 2002 | 03:53 PM
delSolLS's Avatar
Default Oversize Piston?
I am rebuilding a B18B engine. The machine shop that looked at the block says it needs to be bored .020". I have searched this site and others that say that is the maximum overbore a B series block can have before being resleeved.
The Helm's manual says the the service limit for the B18B and B18C is .25mm (.010). Machine shop says it will be OK, but I'm not sure I want to take the chance.
If it needs .5mm bore should I resleeve?
Don't have the $$$ to do it twice!
[Modified by delSolLS, 12:54 AM 1/24/2002]
Old Jan 23, 2002 | 05:27 PM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: Oversize Piston? (delSolLS)
well you should be ok.... most oversized pistons come in .25 over. And the sefest u can bore out a block is 1mm(for all motor) and if you are going FI then the most u should take out is .5mm(which is about .25 ", what needs to be done to ur block)
later
manny
Old Jan 23, 2002 | 06:29 PM
delSolLS's Avatar
Default Re: Oversize Piston? (mannyman)
I;m going NA, but the difference in the Honda specified service limit and what everyone says is "ok" to do bothers me. There is always great info on the board, I just want to do everything right the first time.
Why does the Helm's manual say the rebore service limit is .25mm?
Do I need to resleeve if I need to go over .25mm?
Anybody else have some info on this subject?
Thanks for the help.
[Modified by delSolLS, 3:32 AM 1/24/2002]
[Modified by delSolLS, 1:54 PM 1/24/2002]
foca
May 12, 2008 12:16 PM
nblanton
Oct 5, 2007 03:14 PM
DragSource
Mar 31, 2005 11:26 AM
90da4dr
Jun 26, 2004 06:58 PM
2K_TEG
May 11, 2002 09:10 PM
