Overheating when stopped/idling
Old Jun 23, 2006 | 10:55 PM
Touge Tuning's Avatar
Default Overheating when stopped/idling
K recently ive been having a problem with my car where if its at operating temp and i come to a stop light and im sitting for a minute or so the temp gauge will rise. Now the thing that is weird about it is that if it starts to rise and i give it some throttle (in neutral) it will drop back down to normal pretty much instantly. So im thinking its either my thermostat or water pump, just wondering if you all had any input.
Old Jun 24, 2006 | 01:45 AM
Flashmn's Avatar
Default Re: Overheating when stopped/idling (Stealth1)
Do your fans work?
Old Jun 24, 2006 | 10:32 AM
Default Re: Overheating when stopped/idling (Flashmn)
im gonna try jumping it but i do think that they work.
Old Jun 24, 2006 | 12:08 PM
Flashmn's Avatar
A stuck thermostat would overheat all the time, as well as a broken waterpump. Only reason I can come up for your overheating is the fans.
Old Jun 25, 2006 | 04:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">A stuck thermostat would overheat all the time, as well as a broken waterpump. Only reason I can come up for your overheating is the fans. </TD></TR></TABLE>
reason i dont th ink its a fan problem is because it happens in the same amount of time whether its really hot outside or whether its a cool summer evening. Might not be exactly the same amount of time but i havent had any problems in a year and this just started happening.
Old Jun 26, 2006 | 08:30 AM
lightcrx's Avatar
id change the water pump, timing belt,tensioner and thrmostat its probley time for it anyways..
how many miles are on the engine.
could be thrmo half stuck, enough to let water through when reved but not enough to idle causing overheating
-joseph
Old Jun 26, 2006 | 11:56 AM
Crispy's Avatar
Default Re: (lightcrx)
how about the simplest answer. I had the same problem with my civic. Turned out to be air in the lines.
Old Jun 26, 2006 | 05:38 PM
NathanielH's Avatar
Default Re: (Crispy)
if the tstat was stuck partially open it would overheat on the highway, and have a hard time keeping at operating temprature at idle. at least that is what i have been told/ experienced
Old Jun 26, 2006 | 06:40 PM
checked it out today and seemed like it was kinda low on coolant so i filled her up quickly cause i had to leave but will check it out more tomorrow. thinking I might need a water pump replacement cause thats the only place i could see me losing any coolant which would be from the weeping/telltale hole.
Old Jun 26, 2006 | 07:42 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crispy &raquo;</TD></TR><TR><TD CLASS="quote">how about the simplest answer. I had the same problem with my civic. Turned out to be air in the lines.</TD></TR></TABLE>
Yep, gotta have the system full and the air bled out.
Old Jun 26, 2006 | 10:33 PM
system was full and bled and has not been openend since so there is an underlying problem somewhere which im gonna guess is at the water pump
Old Jun 27, 2006 | 03:14 AM
Chiovnidca's Avatar
Default Re: (Stealth1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth1 &raquo;</TD></TR><TR><TD CLASS="quote">system was full and bled and has not been openend since so there is an underlying problem somewhere which im gonna guess is at the water pump</TD></TR></TABLE>
Is it leaking?
Old Jun 27, 2006 | 11:49 AM
havent checked yet but im going to, if so i will be purchasing a new pump, timing belt and tensioner.
Old Jun 27, 2006 | 06:17 PM
ms e kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">id change the water pump, timing belt,tensioner and thrmostat its probley time for it anyways..
-joseph</TD></TR></TABLE>
yup. It is most likely the water pump and all that good stuff because i had the same exact problem.
gqstatus05
Mar 2, 2012 08:10 AM
my93accord
Nov 15, 2007 07:15 PM
xXx Justin xXx
21
Mar 19, 2004 05:26 PM
mb96civic
Feb 5, 2004 05:39 AM
P1mpSlap
Jun 17, 2003 07:27 AM
