overheating issue?!? lost...
Old Jun 20, 2010 | 09:28 AM
thegatekeeper14's Avatar
Icon2 overheating issue?!? lost...
alright on my turboed car im having a super hard time with it over heating. ive "burped the system countless times (radiator cap off)
ive replaced the thermostat 3 times thinking i had faulty ones.
stil over heated so i just took it out and it still over heats.
ive fixed all the leaks that i can see. i had 2.
my fan is wired up so that while inside the bay its pulling air in.
now it seems that on the highway for the most part its ok. but better when the heats on and slowly creeps down to normal opperating temp. i could also let it idle for what seems like for ever without it over heating.
im not running coolant to the throttle body nor to the iacv.
im so fed up with this thing i just got it tuned and want it fixed by the weekend i just dont know were to start. i would hate to through parts at it without knowing what could be wrong.
Old Jun 20, 2010 | 01:54 PM
fukenricen's Avatar
Default Re: overheating issue?!? lost...
i am having the exact same issue today
i also did everything on your list
Old Jun 20, 2010 | 02:20 PM
HamiltonRex's Avatar
Airflow to the rad, too much heat under the hood.. your cooling system isn't efficient enough.
I think its so funny when guys have a small single core half rad on a huge angle with a single ebay fan, and a big front mount blocking all airflow and there asking why their car is overheating. :/ Then add miles of exhaust manifolds and other hot things under there with no coatings on them.
Theres also a million threads on this. Same thing happened to me in my crx 5 years ago. The rad needs airflow!
Old Jun 20, 2010 | 05:15 PM
i have a koyo dual core radiator and really nice fan on there not from ebay. i just got retuned at 515 and have had the same radiator/fan/intercooler setup for the past 3 yrs now.
Old Jun 20, 2010 | 08:10 PM
fukenricen's Avatar
i been at it all day , i noticed at the end the fan as pulling vs pushing threw the rad, i hope that was the issue.
also for driving around what is the max temp the car should be at , i seen today about 200f
Old Jun 20, 2010 | 08:12 PM
Notes' F22c1's Avatar
Well hopefully that can fix it... by the way do you have a thermostat in it?
Old Jun 20, 2010 | 08:15 PM
Never mind on that comment.... I see u dont have one in there now.. not really sure what can be the problem unless you want to just put some water wetter in it to cool it down...
Old Jun 21, 2010 | 08:33 AM
im gonna pull the hood off and see if it still over heats.
Old Jun 21, 2010 | 08:41 AM
kyden's Avatar
pull the bumper off. the hood isn't gonna do anything for airflow through the radiator.
Old Jun 21, 2010 | 09:11 AM
dpetro1's Avatar
x2
Old Jun 21, 2010 | 04:15 PM
fukenricen's Avatar
its so weird i am having the exact same issue for two days now
motor has about 200k on it and im running water and water wetter, i bled the system completely and even tried a new rad and thermostat and she still gets to over half.
i really have no idea what is going on, i did a new turbo manifold and installed a t04z which takes rad lines to cool her down
Old Jun 21, 2010 | 05:20 PM
fcm's Avatar
fcm
Old Fart
Have you guys checked your water pumps?94
Old Jun 21, 2010 | 08:38 PM
fukenricen's Avatar
so far i think i found my issue, its so stupid but so far car is running fine, i did a leak down test and motor is healthy ,, i removed one flap i had covering the vent on the passenger side where fog lights would usually go and so far so good. the rad wasnt really getting any air from outside doto the cooler being in the way
Old Jun 21, 2010 | 10:30 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Sounds like headgasket issues.
WaryDriver
Aug 11, 2012 11:11 PM
jdmchickx
Nov 10, 2011 12:59 PM
illicit^
14
Jul 5, 2007 10:09 AM
shadowdawn
Oct 6, 2003 10:19 AM
