Overheating b16a2
Old Jul 25, 2003 | 08:33 PM
Raff's Avatar
Default Overheating b16a2
OK.. this maybe the wrong forum to post this in but i felt it applied more than the hybrid section. I've got a 94 ex with a b16a2 in it... it's overheating. Now , we changed the thermostat 3 times, new water pump, purged radiator twice. There is no smoke/ water comeing from my tailpipe yet when I drive the sucker for more than 7-8 min it starts getting hot and after about 10 min over heats. The mechanic I took it to says it's either a blown headgasket or the head is cracked.. If I cracked my head wouldn't there be some signs??? plz help as I have no clue what is causeing this and have already spent quite a bit of money trying to fix it.
Old Jul 25, 2003 | 08:39 PM
Hondasaurs's Avatar
Default Re: Overheating b16a2 (Raff)
Is your fan coming on? If the head gasket or head is bad it will blow white smoke out the exhaust. Make sure you don't have any of yor heater core lines kinked from your swap also.
Old Jul 25, 2003 | 08:42 PM
Raff's Avatar
yeah , already have a 96 gsr harness to plug it all in... idiot who did the swap mangled the stock harness..I have my fan hotwired to run constantly they say they think i cracked the head but.. like i said .. wouldn't there be signs such as smoke?.. think i am looseing oil as well.. could it be a blown headgasket?
Old Jul 25, 2003 | 08:54 PM
Hondasaurs's Avatar
It possible that the head gasket could be the cause of your problem. I would let the car idel and search for any oil or antifreeze leaks. Check for loose hoses and make sure everyting is connected properly.
BlackShingo
May 6, 2010 03:56 PM
hondamike89
Feb 28, 2009 01:40 PM
SoHc94
Sep 3, 2006 11:28 PM
barkwaffle
Jun 15, 2005 01:52 PM
Bobby808
Apr 27, 2005 11:22 AM
