open loop catch can... does it work or not?? (did search)
Old Dec 11, 2003 | 10:44 AM
JCracer723's Avatar
Default open loop catch can... does it work or not?? (did search)
im into making my own oil catch can... ive gone thru like 5 pages from searchin... came up with the basic concept of it... now i came across some1 mantioning the open loop method ... when u just dont hook up the line back to the manifold.. and leting the vapors out of the engine .. does this really work???
Old Dec 11, 2003 | 02:09 PM
martini's Avatar
Default Re: open loop catch can... does it work or not?? (JCracer723)
no, because you need the vaccuum that the manifold provides.
Old Dec 11, 2003 | 02:18 PM
JCracer723's Avatar
Default Re: open loop catch can... does it work or not?? (martini)
ty... now is it really recommended to use steel wool in the can?? has any1 else use any other material?
Modified by JCracer723 at 9:57 PM 12/13/2003
Old Dec 11, 2003 | 04:59 PM
martini's Avatar
not the real fine steel wool. but the thicker, stainless steel stuff.
you can use other materials, sure... but the steel wool is just easy, cheap, and available lots of places.
Old Dec 11, 2003 | 05:28 PM
JCracer723's Avatar
ty
Old Dec 11, 2003 | 09:40 PM
StyleTEG's Avatar
stainless steel wool can rust and break apart, (even the thicker stuff) I wouldn't use it.
You can pick up plastic gutter guard for cheap, and packed together it will filter well. If you want the oil catch can to vent into the air, you need to run with out a PCV valve, and use a slashcut tube in the intake to force air into the crankcase.
Not the best way to do it.
Old Dec 11, 2003 | 10:18 PM
JCracer723's Avatar
Default Re: open loop catch can... does it work or not?? (StyleTEG)
wouldnt the plastic melt??
Old Dec 12, 2003 | 07:52 AM
StyleTEG's Avatar
no, the catch can doesn't start on fire.
Old Dec 12, 2003 | 08:45 AM
JCracer723's Avatar
yes i know but it does get hot... have u done this urself??
Old Dec 12, 2003 | 09:52 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt the plastic melt??</TD></TR></TABLE>If you're worried about that, you can get aluminum gutter guard.
Old Dec 12, 2003 | 09:54 AM
JCracer723's Avatar
Default Re: open loop catch can... does it work or not?? (JimBlake)
ok so wuts proven to work... from personal experience pls... some say steel wood some say that plastic thing.... wut works???
Old Dec 12, 2003 | 06:59 PM
StyleTEG's Avatar
Alluminum can rust also, I personally would not want to be sucking rust into my engine.. but thats just me.
As far as heat, the vapors are coming directly out of the PCV valve, and what is the PCV valve made out of?
Plastic.
Oil vapors are not going to get hot enough to melt plastic or even warm up a catch can.
Old Dec 12, 2003 | 07:04 PM
JCracer723's Avatar
if the can is made out of steel or aluminum.. dont u think the plastic would melt.. now yes the pvc is made out of platic.. but its way thicker than the stuff u puttin in the can
Old Dec 13, 2003 | 01:54 AM
That Dood's Avatar
sorry but i have to say something....
its wool not wood....and its pvc not pvs.
Old Dec 13, 2003 | 12:57 PM
JCracer723's Avatar
Default Re: open loop catch can... does it work or not?? (That Dood)
oooohh fukin god ... u know wut we are talkin about... mystakes .... do any1 in here know?? or just let this **** die.. and ill post it somewhere else
Old Dec 13, 2003 | 03:34 PM
StyleTEG's Avatar
The melt index of ABS plastic is around 220C, thats over 400F. Its not going to melt, oil vapors are not nearly that hot. Christ.
I have made steel and alluminum catch cans, both using plastic baffling, which #1 hasn't melted, #2 the cans have never been hot to the touch even after 20mins of lapping at HPDE events.
#1 Hated
Welding / Fabrication
Apr 22, 2012 07:17 AM
LumpyTheGrumpyCamshaft
11
Feb 23, 2010 10:12 AM
LightningTeg
Apr 29, 2009 05:23 PM
MotoCARR
Feb 6, 2007 02:20 PM
SiR Kid
May 18, 2003 06:36 AM
