only get 1 fire on coil
Old Dec 29, 2004 | 06:59 AM
dirtracer's Avatar
Default only get 1 fire on coil
I changed engines in my '89 Accord. After putting it in it ran good BUT I had to pull it to change the Cluch. Put it in again and now it won't start. I've tried 3 different coils & dist. but it always only get 1 spark fireing from the coil then nothing changed the Relay under dash but still same thing.I need my wheels any help will help. Thanks in advance
Old Dec 29, 2004 | 01:48 PM
tgreaves's Avatar
Default Re: only get 1 fire on coil (dirtracer)
Did you remove the rotor in the dizzy???? Did you remember to put the screw back on it????
Old Dec 30, 2004 | 04:18 AM
dirtracer's Avatar
Default Re: only get 1 fire on coil (tgreaves)
thanks for the repy.I went out after this post found out it's the timeing belt . going out to yak it now and take it back to get another engine it had a broken mount.Thanks again for the input...
Old Dec 30, 2004 | 05:28 AM
tgreaves's Avatar
TIMING BELT... How in the hell does a problem with the timing belt make it only fire 1 cylinder?
d4ng3rb0y
15
Nov 24, 2009 08:15 AM
MakinAComeBack
Classic Hondas
Apr 26, 2008 06:57 AM
PhilipK
Sep 21, 2007 12:43 PM
b18b ef boy
Dec 16, 2006 01:55 PM
snakedoctor
Feb 14, 2006 07:47 AM
