need help with my hatch?
okay i have a problem with my hatchback. the cooling fan does not turn all for any thing. i changed the thermostat , sensor and also put in a new radiator and fan . changed the water pump. the fan wont turn on for any thing . what else am i missing here. did i forget something? and by the way if i wire it direct it works so i know it aint the fan and the fuses are fine too. if any body else has this problem please help . its driving me crazy!!!!!!!!!!!!!!!!!!!!!
Re: (hondaon18's)
i did replace the fan switch. now i remember its that switch thats located in the thermostat housing. also where would the ground be for the the radiator?? if anyone knows
Re: (hondaon18's)
take a peice of wire and connect the 2 wires that go to the switch on the thermostat just plug one end of the wire into each pin should be 2 of them if the fan dont come on with the car started theres a issue with the wiring if it does its the switch my buddys car is running a 90 integra ls which dosent have that switch so we cut the connector off and twisted the wires fan just stays on while the car is started but shuts off when you turn the car off easy fix
Re: need help with my hatch? (hondaon18's)
check ur wiring... mine did same thing and came out the wiring in one plug where fan plug connect is loose and i have to improvise it to make it work...
Re: (hondaon18's)
okay i wired all ghetto like from the battery and it comes so i know the fan works. but you guys are saying that i should disconnect the fan switch plug and put a wire to it and if the fan comes on when i turn my car on then i have a problem with the switch . if im getting that or i might have just confused my self. which switch would i need to replace?
1 Post
Re: (hondaon18's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaon18’s »</TD></TR><TR><TD CLASS="quote"> also where would the ground be for the the radiator?? if anyone knows</TD></TR></TABLE>lol
Re: (hondaon18's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaon18’s »</TD></TR><TR><TD CLASS="quote">okay i wired all ghetto like from the battery and it comes so i know the fan works. but you guys are saying that i should disconnect the fan switch plug and put a wire to it and if the fan comes on when i turn my car on then i have a problem with the switch . if im getting that or i might have just confused my self. which switch would i need to replace?</TD></TR></TABLE> unplug the sensor at the thermostat housing there will be 2 wires on it take a peice of wire and cross them by twisting the ends pressing each end into the plug if your fan turns on the switch is bad not the plug does that clarify it enough for you ?????
Re: (hondaon18's)
okay and the switch would be the piece that is connected to the plug itself???? and if the fan don't turn on what does it mean that my fan switch is bad
Modified by hondaon18's at 8:56 PM 6/4/2007
Lloyd Xmas
04-14-2010 09:21 AM
