Oil Pump Lifespan
Old Jul 12, 2004 | 08:21 PM
kurinto's Avatar
Default Oil Pump Lifespan
I tried to search this, but what is the average lifespan of an oil pump? I have a 98 ls going into my crx and the engine has 83k on it. I really don't want to drop $100 on an oil pump if its gonna last til I do the timing belt again (another 60k miles).
Old Jul 13, 2004 | 07:01 PM
turbohondask's Avatar
Default Re: Oil Pump Lifespan (kurinto)
should last the life of the engine or if you would like to change it for a a piece of mine about 200k should do it
Old Jul 13, 2004 | 07:32 PM
blah13's Avatar
Default Re: Oil Pump Lifespan (turbohondask)
196k on my stock a6 before I pulled it and it worked fine, 185k on my dx and its still kickin. I'd say your good for quite a while.
Old Jul 13, 2004 | 07:41 PM
mmuller's Avatar
Mad Scientist
Default Re: Oil Pump Lifespan (blah13)
yep, if an engine was taken care of, and had nothing bad happen(read; bearing failures or anything that will send metal particles to the oil pump)and used no aftermarket non dampened crank pulley; then the oil pump should have a long long life...
i would say check clearances and if they are good....hit it.
i checked clearances on my 134k oil pump and they were dead on...
Old Jul 14, 2004 | 05:52 AM
kurinto's Avatar
Default Re: Oil Pump Lifespan (mmuller)
Alright, thanks guys.
caliskier
Apr 9, 2012 01:05 PM
Galland
13
Jun 20, 2004 01:23 PM
SleepyHF
Mar 15, 2004 08:26 PM
echo999
Apr 26, 2003 08:58 AM
