Oil Pump Change
Old Feb 5, 2002 | 09:18 PM
echo999's Avatar
New User
Default Oil Pump Change
Hey guys...
I'm pretty certain that I have a failing oil pump.
Any ideas if this is something easily done, or does the engine have to
come out?
It could also be bad pulley bearings.. In this case, hard change out?
Costs?
Thanks in advance!
Old Apr 26, 2003 | 01:11 AM
garagespecial
Guest
Posts: n/a
Default Re: Oil Pump Change (echo999)
free bump cuz id like to know
Old Apr 26, 2003 | 01:21 AM
InfamousRS's Avatar
Default Re: Oil Pump Change (garageSPECial)
It can be done with the motor in the car....you will have to remove the oil pan, oil pick up, *possibly the uper drivers side mount, timming belt cover, timming belt, main pully, then all the bolts holding the pump in, then the pump will come right off. Not somthing I like to do while the motor is in the car, but it CAN be done.
Old Apr 26, 2003 | 01:25 AM
Kwuaymaikrup's Avatar
Default Re: Oil Pump Change (InfamousRS)
I've done it...only took me about 40 min after all the fluid was drained. Good luck
-Ryan
Old Apr 26, 2003 | 02:27 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Oil Pump Change (Kwuaymaikrup)
Why do you think you have a bad oil pump? An oil pump is just a gear and not anything mechanical like a fuel pump is. Unless it shatterd.
art
Old Apr 26, 2003 | 06:20 AM
Flamenco-T's Avatar
how 's your oil pressure ?
check your oil pressure at idle...oil pump hardly fails under stock style driven car, unless you're revving to 10K, it may be another issues...
stan
Old Apr 26, 2003 | 08:58 AM
inspyral's Avatar
Default Re: Oil Pump Change (Flamenco-T)
Getting the crank pulley bolt off while the engine is still in the car is a major pain, unless you have a compressor and an air gun.
crazyslowhatch
Oct 17, 2004 10:04 PM
Mefain
May 16, 2003 09:02 AM
garagespecial
Apr 26, 2003 01:16 AM
