help me identify these
from left to right:
i believe the first is an o-ring for the water pipe, then the gasket for the oil pickup, the 3rd has me stumped, and i was told the last piece is not to be used on my b18b. can anyone confirm? thanks.
that 3rd o-ring is either for the dipstick tube where it installs to oil pump housing, or oil pump outlet between block and oil pump housing. You will be able to tell once old pump housing is removed.
I'm pretty confident that it is the o-ring for the oil pump outlet between pump housing and block.
If you find that it is the dipstick tube o-ring, yes, you can reuse your existing o-ring on your dipstick tube but why not go ahead and install the new one?
Just letting you know.
Hope this helps...
Modified by hondatim at 9:14 PM 2/7/2004
Hope this helps...
nighttrain33
Oct 3, 2006 07:30 PM
