oil pressure and vtec
Old Apr 14, 2003 | 09:29 PM
Cashflo's Avatar
Default oil pressure and vtec
if the oil pressure sensor light is "On" does that mean my vtec is disabled? Also can someone tell me the obvious as to why the oil light is on. My oil level is good, no leaks. could it be the oil pump? also im using a pr3 obd-1 ecu for my motor (b16a1 head w/gsr bottom). could this affect timing?
Old Apr 14, 2003 | 10:04 PM
91DA9's Avatar
Default Re: oil pressure and vtec (eghead)
If you have been driving with your oil light on then I would say non-functioning VTEC is the LEAST of your problems...
Old Apr 15, 2003 | 08:55 AM
JimBlake's Avatar
If your oil pressure were really below about 2psi (where the light comes on) you'd already have messed up your engine. Since it has survived(??) then I'm thinking a bad pressure switch or bad wiring.
Old Apr 15, 2003 | 07:16 PM
Cashflo's Avatar
Default Re: oil pressure and vtec (JimBlake)
say i did mess up my engine, would it be running? my fluids are still good.
Old Apr 15, 2003 | 09:18 PM
psi420's Avatar
If that oil pressure light is on, that means you have no oil pressure in your motor!
Your oil filter is empty, and you have no oil pressure saturating your bearings.
Now since the switch works on a ground, if you had a bad connection, you should see no light at any time.
VTEC is the least of your worries now.
And yes, VTEC wont work.
Old Apr 16, 2003 | 12:35 AM
Cashflo's Avatar
Default Re: (psi420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">If that oil pressure light is on, that means you have no oil pressure in your motor!
And yes, VTEC wont work.</TD></TR></TABLE>
so your saying that if i had bad wiring it wouldnt light up? lets say i had the right oil pressure and the light is still on (bad sensor), would my vtec still be disabled?
Old Apr 16, 2003 | 03:20 AM
Chiovnidca's Avatar
Default Re: (eghead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghead &raquo;</TD></TR><TR><TD CLASS="quote">
so your saying that if i had bad wiring it wouldnt light up? lets say i had the right oil pressure and the light is still on (bad sensor), would my vtec still be disabled?</TD></TR></TABLE>
If you have proper oil presure, VTEC should work (considering no other VTEC problems) regardless of the light.
Schultzie
Jul 10, 2010 08:58 PM
stevenDAtegra
Jul 6, 2009 04:18 AM
lojackgsr
Jun 24, 2007 11:17 PM
Cashflo
Apr 17, 2003 03:20 PM
