broken oil pressure sending unit??
Old Apr 15, 2003 | 12:54 PM
sir2chad's Avatar
Default broken oil pressure sending unit??
i took off the oil pressure sending unit to hook up an oil pressure gauge and the little tip on the end broke off...can i get by with out this till i get a new one in a few days...or is this gonna mess up anything in the ecu?? please let me know
thanks
Chad
Old Apr 15, 2003 | 12:56 PM
sgT's Avatar
sgT
Default Re: broken oil pressure sending unit?? (sir2chad)
it only controls the light on the cluster and if you are going to have a pressure
gauge then you dont even need it
Old Apr 15, 2003 | 01:00 PM
sir2chad's Avatar
Default Re: broken oil pressure sending unit?? (sgT)
bitchin...i wasnt sure if it just connected to the dash or if it ran to the ecu also...but if its just for the warnin light then ill be fine with just the gauge for a bit....thanks
chad
Old Apr 16, 2003 | 04:10 AM
JimBlake's Avatar
Does the sender for your gauge already have a terminal for the idiot light? Some of them do - check it out. If so, just use that.
boostgegsr
Dec 6, 2011 07:01 AM
crxjarred
Jun 16, 2010 10:24 AM
B18badboy
Apr 12, 2006 07:17 PM
graphic
Dec 7, 2004 10:31 AM
