Oil light flickering
Old May 27, 2003 | 03:33 PM
B18EG6's Avatar
Default Oil light flickering
I noticed sometimes when I come to a stop and the revs drop, the oil light comes on. You might have read my other post regarding grounding the oil pressure sender on the firewall.
please refer to this for pictures.
https://honda-tech.com/zerothread?id=516830
I grounded the sensor today, yet when I come to a stop sometimes the oil light comes on. Why is it doing this? I put a little under 5 quarts of oil in it....
thanks
Old May 27, 2003 | 06:20 PM
Chiovnidca's Avatar
Default Re: Oil light flickering (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">
Low oil presure maybe?
Old May 27, 2003 | 06:45 PM
dfoxengr's Avatar
Default Re: Oil light flickering (Chiovnidca)
the oil moves when youre stopping, also low pressure can cause it or a crapped out pump
Old May 27, 2003 | 11:48 PM
teamgobler's Avatar
Default Re: Oil light flickering (hybridvteceg)
I've experienced a similar problem to this. Believe me! don't drive your car any further until you ve had it checked out.
I used to drive a DA7 (4 door ZC powered integra) which blew its big end bearings after about a week of the oil light flickering on and off, just like yours is. Of course I thought it was just a faulty oil pressure switch. Turned out to be a a screwed oil pump that was falling into low pressure at times. Oh well, about a grand later I got a new motor put in.
Oil is like the blood that runs through our engines, low pressure is just as bad for us as it is for cars.
seeya
Old May 28, 2003 | 12:51 AM
B18EG6's Avatar
yes i fear the oil pump is the culprit.... when i noticed the light flicker, i reved the motor and noticed the light quickly went off.
Argh dammit how hard is it to put a new oil pump in? I just got the car running again today for the first time since like focking november, seeing as how i was never home during the school year...
ive been boosting hard with no problems, i prolly shouldnt test my luck further should i?
Old May 29, 2003 | 11:58 PM
teamgobler's Avatar
Because it was too late for the ZC motor in my old teg, we just took out the whole motor and putin a new one. The oil pump was easy to get to wonce out of the car. In the car, i'd imagine you would have to remove the cam belt, wires, and maybe the intake mani to get to the pump. Not completely sure what would be involved.
If it is the oil pump than your ride might last a month or it might blow a big end tomorow. If I was you I wouldn't risk it, Thats what I did and it did not do nice things to the rods and crank
Old May 30, 2003 | 08:45 AM
B18EG6's Avatar
Default Re: Oil light flickering (teamgobler)
Yeh... Im not going to risk it.
The light flickers when i come froom going real fast, to a stop... it flickers for a second then goes off.
Do you know at what psi the light is triggered? Should I go with a stock gsr pump?
Old Jun 1, 2003 | 07:36 PM
teamgobler's Avatar
Sorry, I'm not really sure at what pressure the light begins to flicker. As your motor is forced fed, it might be a good idea to have an oil pressure gauge. I don't think these are necessary, but could be useful in early detection of problems like these.
It would be safe to say that a new stock GSR pump will work fine. I'm not to familiar on what the specs are or how the after market pumps perform. Most of the turbo civics i've seen run the stock pump and maintain sufficient of oil pressure
Old Jun 1, 2003 | 08:42 PM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamgobler &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, I'm not really sure at what pressure the light begins to flicker. As your motor is forced fed, it might be a good idea to have an oil pressure gauge. I don't think these are necessary, but could be useful in early detection of problems like these.
It would be safe to say that a new stock GSR pump will work fine. I'm not to familiar on what the specs are or how the after market pumps perform. Most of the turbo civics i've seen run the stock pump and maintain sufficient of oil pressure</TD></TR></TABLE>
thanks.... ima order a new oil pump ASAP and see if that fixes the problem
mtownek9
Apr 1, 2008 01:54 PM
motormike40
Aug 21, 2006 06:02 PM
spooncivic1
Mar 2, 2006 08:20 AM
Foxcow
10
Dec 16, 2004 08:56 PM
lemongreenhatch
10
Aug 15, 2004 06:47 AM
