oil level???
Old Dec 23, 2007 | 02:59 PM
Dac's Avatar
Dac
Default oil level???
I have a EG hatch with a h22 H2B swap in it. Im using the Evolution H2B kit. The motor sits forward in the engine bay so when i add four quarts it reads above the second dot on the dipstick. Do i add more oil for leave it the way it is? Need opinions. Thanks
Old Dec 23, 2007 | 06:59 PM
zuum's Avatar
Default Re: oil level??? (Dac)
the h22 actually take 4.2 quarts... so you must still have some old oil in there... too much oil will ruin bearings just as well as too little, so it really depends on how FAR above the top dot you are...
Old Dec 24, 2007 | 11:41 AM
Dac's Avatar
Dac
There is no oil in it. I had to take the oil pan off before i put it back together. Im aware that too much oil is bad thats why i made this thread.
Old Dec 24, 2007 | 05:02 PM
blwn95civic's Avatar
did you change the oil filter also? if not thats where your extra oil came from....
IMO as long as your readin ok on the dip stick you should be fine, the motor sits at the same angle in your car as it would in any other car with the correct mounts
Old Dec 25, 2007 | 10:44 AM
Dac's Avatar
Dac
got it taken care of thanks.
dc4JDMh22
May 29, 2013 12:30 PM
EG_Civic_Si
Feb 6, 2011 04:05 AM
Inextricabledrvr
May 3, 2008 09:42 AM
HondaEJ7
Feb 13, 2006 05:18 PM
darkdementshun
Aug 18, 2005 01:05 AM
