Oil Filter Holder B18B
Old Apr 21, 2011 | 08:53 PM
kpjo4's Avatar
Default Oil Filter Holder B18B
I bought a B18B1 block not too long ago but it seemed it didn't have a oil filter holder (part #90015-PH1-013 ), does anyone know how to install these or the torque specification for it?
It's the part in this diagram that I circled in blue (15).
Old Apr 22, 2011 | 09:49 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Oil Filter Holder B18B
torque on.
if comes looose when switching out filters then jus tighten it agian.
if you get a #12 part in your diagram from a diff b18 block you can do away with it and just put the filter onto the cooler.
Old Apr 22, 2011 | 06:00 PM
IN VTEC's Avatar
I used the oil thread adapter from a sandwich plate to tighten it down. I also used a light coat of sealant on the threads.
Old Apr 22, 2011 | 07:34 PM
kpjo4's Avatar
what kind of sealant could take the block's heat? rtv red?
btw thanks for the respponses =]
Old Apr 22, 2011 | 07:42 PM
known's Avatar
Originally Posted by rick_rabies
torque on.
You are making it seem like the oil cooler setup is a bolt on setup.
You can use the oil cooler on the b18b but modifications will have to be made for it to work properly.
Old Apr 22, 2011 | 08:19 PM
kpjo4's Avatar
i'm guessing all you will need extra are parts #11,12, and 19 with a coolant line tapped into the cooler?
Old Apr 22, 2011 | 09:15 PM
known's Avatar
Those plus tapping the block and getting the fitting, coolant pipe, cooler hoses.....not exactly rocket science but it would take some time. if you mess up when you tap the block you will have to get a custom fitting and go bigger.
Old Apr 22, 2011 | 10:16 PM
kpjo4's Avatar
speaking of tapping the block, i tried putting in the oil filter holder with a oil filter onto it and started torquing it down, it didn't fully flush so i stated to loosen it and the part got stuck into the oil filter and I looked to see that the threading in the block is a little stripped, would it be best to re-tap the block or just trash it =[? ****
Old Apr 24, 2011 | 03:51 PM
kpjo4's Avatar
bump, does anyone know the thread size and pitch for the part of the oil filter holder that goes inside the block?
Old Apr 25, 2011 | 11:30 AM
kpjo4's Avatar
bump, come on anyone know anything about this?
Old Apr 25, 2011 | 11:44 AM
Garage 808 Hatch's Avatar
There is a little section of non threaded area (atleast on the ones ive bought) use a little loctite on the threads into the block, thread it in by hand and snug it up the last bit with channel locks on the non threaded part.
Old Apr 25, 2011 | 07:32 PM
kpjo4's Avatar
That I will do, but now I have tap the block where the oil filter holder should bolt in, but I do not know the specs =[
kpjo4
Apr 21, 2011 09:13 PM
asubennett
Apr 13, 2006 04:06 PM
GReddyB18C
Jan 30, 2002 06:25 AM
Type Goch
Jul 1, 2001 10:11 AM
