Buring oil
Old Jun 13, 2008 | 08:44 AM
Hharrishonda's Avatar
Default Buring oil
I changed my oil about a month ago and im not sure why its burning oil will new rings and and pistons help or is it because off high rpm
Old Jun 13, 2008 | 04:54 PM
surfthethirdcoast's Avatar
Default Re: Buring oil (Hharrishonda)
Depends on when the oil is being burnt...Oil being burnt at higher RPM's is a good indication of worn out rings. Oil being burnt only at startup is a good indication of worn valve seals. Hope this helps...
Old Jun 14, 2008 | 05:59 AM
The_Honda_Guy's Avatar
Could have put the wrong size rings or pistons in or could be another problem. You need to do a leakdown test to discover where you're losing it.
Takumi Fujiwara
Feb 23, 2006 08:18 AM
Sl0wEK
Dec 5, 2004 10:12 PM
IloveNewt
Dec 21, 2003 10:18 AM
lopey
Feb 5, 2002 09:46 AM
GruvyTune
Jan 28, 2002 06:23 PM
