Oil and Coolant Mixture everywhere in engine.
Old Dec 26, 2003 | 02:50 AM
MugenB16A2's Avatar
Default Oil and Coolant Mixture everywhere in engine.
I just finished assembling my LS/VTEC and today I installed it, and when my buddy and I first gave it a start, it took us a few tries (as expected) but when it started to idle for about 30 seconds, we noticed the Coolant resevoir Overflowing!!
So, I immediatly shut the car down, and we opened the resevoirs to Find a Coolant/OIL Mixture!!
What happened???
We removed the valve cover to find coolant all over the rocker arms and inside the head.
Finally I we said to ourselves, "Better take the head off".
Well, when we did, there again was this residue of OIL and Coolant.
However, The Spark Plugs were fine, not saturated or anything, still looked new, just like before I put them in.
And as for the Cylinder Walls, they were dry as well..
Can anyone help me PLEASE?? I am lost, and VERY tired, I have been up all night.
What happened???
Old Dec 26, 2003 | 09:19 AM
MugenB16A2's Avatar
HELP ME!!!!!!!!!!
Old Dec 26, 2003 | 10:00 AM
Turbogixxer's Avatar
Default Re: (MugenB16A2)
how did the headgasket look? was it lined up right? it sounds like a head gasket. btw you running a stock oil cooler? you have have switched up the lines.
Old Dec 26, 2003 | 10:03 AM
BROOD's Avatar
Default Re: Oil and Coolant Mixture everywhere in engine. (MugenB16A2)
Things I would check:
Correct headgasket used?
Dowel pin height too much? (I would check this out)
Flat deck on block and cyl head?
Correct torque on headbolts/headstuds?
Oil cooler core possibly shot? (longshot)
Measure dowel pin hole depth on both cyl head and block, factor in headgasket crush thickness...then compare to measured height of dowel pins. You may need to gind them down to allow full seating of cyl head to block surface.
Old Dec 26, 2003 | 11:46 AM
MugenB16A2's Avatar
Default Re: Oil and Coolant Mixture everywhere in engine. (BROOD)
There is no Oil Cooler on this motor, I am using a B16 water neck, not the ITR one that has the extra outputs for coolant to oil filter.
I don't know what else it could be. I am using the Golden Eagle, Dowel Pins, and I don't know if they pose a threat, has anyone used them before???
Old Dec 26, 2003 | 01:30 PM
MugenB16A2's Avatar
Whats the best way for me to Flush out my oil and coolant galleys???
Also, can I reuse the NEW oil filter I had in it??? I pretty much filled it with oil, and dumped it out about 4 times, to get as much of the coolant out as possible.
Old Dec 26, 2003 | 01:34 PM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenB16A2 &raquo;</TD></TR><TR><TD CLASS="quote">Whats the best way for me to Flush out my oil and coolant galleys???
Also, can I reuse the NEW oil filter I had in it??? I pretty much filled it with oil, and dumped it out about 4 times, to get as much of the coolant out as possible.</TD></TR></TABLE>NO DO NOT reuse the filter it is ruined.
Old Dec 26, 2003 | 02:08 PM
MugenB16A2's Avatar
Default Re: (fkned)
Filter Ruined Heard
Old Dec 26, 2003 | 03:17 PM
MugenB16A2's Avatar
Old Dec 26, 2003 | 03:47 PM
ArinX's Avatar
sorry to hear that man, my only guess would be missalignment of the headgasket? I remember on a different thread u said u modified the headgasket to make the dowl pins fit. maybe that played a role in this?
Hope you get it fixed.
Old Dec 26, 2003 | 03:58 PM
MugenB16A2's Avatar
Default Re: (ArinX)
Thanks, yes apparently the headgasket holes for the dowel pins NEED to be "Opened or Honed" in order for the Golden Eagle Dowel Pins to fit.
Can anyone shed more light on this subject?
Old Dec 26, 2003 | 09:45 PM
MugenB16A2's Avatar
tttt...
Tried a new gasket today... DID NOT remove the factory keepers (brass rings) for the head gasket.
Only thing I modified was the holes for the dowel pins on the exhaust side.... (stud holes on exhaust side on each end of the block....)
Im lost...
What do most people use for dowels ?
I know you can drill your head & use factory ls dowels so you dont have to modify your headgasket....
Any pics/advice etc would be great....
Old Dec 26, 2003 | 09:50 PM
ArinX's Avatar
Thats what i had done to my head when alaniz was doing a valve job i had him prep it for the dowl pins as well. I have yet to drop the motor in yet tho.
Old Dec 26, 2003 | 10:09 PM
MugenB16A2's Avatar
Default Re: (ArinX)
What did you have prepped ?
What did you have "it" prepped for ?
Gimme some more details on your dowel/headgasket setup please.
Old Dec 27, 2003 | 02:27 PM
ArinX's Avatar
Well all he really did was drill out the head so the stock location of the LS dowl pins would be accepted.
monkfe
Jan 13, 2010 04:55 AM
boostedjdmdc2
Jun 2, 2009 08:49 PM
BigRonDawg
Jan 19, 2009 01:35 PM
Sam268
Mar 2, 2004 10:20 PM
